Username: Lukep90 Washington
Post Number: 1 Registered: Mar-08
Sunday, March 23, 2008 - 19:25 GMT alright, what would you pick??? CDT Audio EF-61NEO or Rainbow slc 265??? i have a 350z so the mounting depth/ magnet diameter is an issue.... thanks!
Post Number: 3 Registered: Mar-08
Sunday, March 23, 2008 - 19:26 GMT any other suggestions greatly appreciated...
Username: Nd4spd18 Northwest PA
Post Number: 6954 Registered: Jul-06
Sunday, March 23, 2008 - 19:30 GMT Can't say I've ever heard either of those. But for what it's worth, CDT's HD series are very good.
Username: Exige Cincinnati
Post Number: 195 Registered: Nov-07
Sunday, March 23, 2008 - 19:56 GMT What's your car's mounting depth?
Post Number: 196 Registered: Nov-07
Sunday, March 23, 2008 - 19:56 GMT Also what's your budget?
Post Number: 4 Registered: Mar-08
Monday, March 24, 2008 - 00:52 GMT its kinda tricky... Depth from wall at 2.2" (56mm) seems to fit any magnet diameter. Past that depth (or at least at 2.45" or greater depth), magnet diameter becomes significant i am told that the DLS UP6 fit, as well as the JL Audio C5-650s. the 650s have a mounting depth of 2.54" and a magnet diameter of 3.44".
Post Number: 5 Registered: Mar-08
Monday, March 24, 2008 - 00:56 GMT and budget for speakers only is roughly 250. can push it a little for speakers that are a lot better. and btw, those JLs are supposidely just a little too big magnet wise, and require some adjustments/mods. thanks! p.s. exige, have you heard the EF-61NEOs? i wonder how they compare to the HDs. have heard them and love em.
Username: Alteraudiousa Concord
Post Number: 1617 Registered: Jan-06
Monday, March 24, 2008 - 01:04 GMT As a CDT dealer I have used the EF Neo, they're actually sitting next to me(new set) and they're good for the depth. Lack the midbass a normal set would give but they have an nice warm sound to them. OP, i've sent you a message check on it.
Username: Adddisorder Palm Beach,
Florida
Post Number: 6112 Registered: Jan-06
Monday, March 24, 2008 - 22:16 GMT i love that rainbow set i would go for it and give them good power
Username: Croozer Rockford,
IL
United States
Post Number: 57 Registered: Feb-06
Saturday, March 29, 2008 - 15:45 GMT Dynaudio 242GT
