I did a blind scan to get new/changed channels and I ended up with 4/5 of the same channels so I deleted all channels and did a new scan. Again I have multiple channels. I also lost my local channels 3,5,10,15,44,55.
Is there any way to delete the duplicated channels?
try it: All viewsat box Go to Code menu Select Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00 Delete this 3 provider one by one with F3 on remote no need to delete keys delete switch off 10 secs on back panel and load last bin for your box turn autoroll on Keep on Bin and autoroll regenerete keys Resolve problem with lost channel , autoroll and search signal
Thats erase bad data in the box For box who lost channel and sat setup ENJOY TV
TESTED and work fine New issue for problem on Viewsat Thanks
Do a blind scan on your sat after for recover all channel Because some new freq are provide Dont do a factory reset and factory bin No need it
