Bronze Member Username: Deptrai_cachonPost Number: 47 Registered: Jan-08 | hi..I have VS Ultra ... I was trying to load new bin and my power went out .. now it won't turn on . so it is burned , do I need new receiver .. or anything I can do to save it .. ? any help guys ... thank you in advance !!! |
Gold Member Username: Mc_sunnyPost Number: 1243 Registered: Feb-06 | Get a "Factory Bin file" & transfer this data from the PC to the Viewsat STB using the standard Loader2 procedure... Once the STB front panel goes to "0 0 0 0?, you may turn off the Viewsat STB... Using Loader2, again find the "Current Bin file" to program your Viewsat STB using the standard Loader2 procedure... Once the STB front panel goes to "0 0 0 0?, it is safe to turn off the Viewsat STB... If you have a special "satinfo.sat" satellite file, use Loader2 and the standard data transfer procedure to transfer that data from your PC to Viewsat STB. The Viewsat STB should now be back in good working condition... If not, you've lost nothing by trying and should try this multiple times before giving up. |
Gold Member Username: RtapFL Post Number: 2030 Registered: Jan-07 | you probably loaded the wrong bin. did you load this one pftausw-080311u.zip |
Bronze Member Username: Deptrai_cachonPost Number: 48 Registered: Jan-08 | sorry i;m very new to this .. i tried to load bin pftausw-080311u.zip lastnight.. and it froze... so I turned off the main switch in the back .. and now this is what happen my vs is not turn on now ... when try to turn on the main switch in the back .. the light in front show "---- " and the TV screen said " NO SIGNAL " so how can I load the Loader2 . .do I use the cable or usb >>?? will it work with the blank screen ?? and where can I get loader2 ?? |
Gold Member Username: RtapFL Post Number: 2032 Registered: Jan-07 | try loading the factory bin then the new bin |
Platinum Member Username: LklivesPost Number: 14580 Registered: Jan-06 | U have power...U just have nite rider lights..its a simple fix.. U need to go to a site that has files and the instructions to resolve your simple problem...theres a thread here listing other sites.. |
Bronze Member Username: Deptrai_cachonPost Number: 50 Registered: Jan-08 | lk what site ? what thread ?? can u link me there please .. i;m very stuckk right now thanks |
Bronze Member Username: Buyer2007Post Number: 13 Registered: Mar-08 | Thread: Best Satellite FTA Info sites |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 826 Registered: Jan-08 | Ken go to viewsatusa.com/support.htm download and install: VSPRO Loader - Firmware Updater ( Serial) and download : VS2000 ULTRA Factory Bin File - V0132 open it and load it do a hard reboot and load last bin. If you loose your data, that because your box is need clear data, read it: https://www.ecoustics.com/electronics/forum/home-video/459283.html Good luck |
Bronze Member Username: Deptrai_cachonPost Number: 51 Registered: Jan-08 | plymouth or lk ..so do I need to load the factory bin or the loader2 ? ? or both ?? my tv screen is blank right now .. will i be able to load them by serial cable ? |
Gold Member Username: RtapFL Post Number: 2040 Registered: Jan-07 | ken go to viewsatusa.com get both factory file and loader there.load the factory file then load the current file thats it |
Bronze Member Username: Deptrai_cachonPost Number: 52 Registered: Jan-08 | ok ... i'll try it then i'll let you guy know ... thank you for all your help guys |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 830 Registered: Jan-08 | Ken the loader is for install on computer and with it you load factory bin if need info reply. |
Gold Member Username: KirankumarI will not b... Post Number: 2100 Registered: Oct-07 | Ken, download the loader,you need this to download files to your receiver next download factory file 132 and unzip it hook up your receiver with cable to pc keep receiver turned OFF now open loader and bring the unzipped file into loader now press pc to stb and turn your receiver ON do Not do anything until the download finishes. once that is done download latest bin and unzip it again with receiver OFF open loader and bring that file into loader and press pc to stb and turn receiver ON wait until it finishes then turn receiver OFF and hook up to tv and connect all cables and turn receiver on if you have any problems post here and i will give you step by step instructions |
New member Username: TsuratPost Number: 10 Registered: Mar-05 | I think one has to be careful when to install the remote fix bin for viewsat as I had the same problem. followed your instruction in this thread and it works fine now..thanks to all |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 832 Registered: Jan-08 | YES African it's true I forgot procedure Ken after load factory bin. You can use USB for download. |
Bronze Member Username: Tgyoung1Illinois U.s.a. Post Number: 14 Registered: Jul-06 | pansat 2700a going off and on scramble channels..? |
Platinum Member Username: LklivesPost Number: 14590 Registered: Jan-06 | That is the simple NITE RIDER ---- dashing lights fix...it works on ALL receivers, regardless of make amd model...the only thing that will change is the loader and factory file U would use for other receivers... |
Bronze Member Username: Deptrai_cachonPost Number: 53 Registered: Jan-08 | african, turning the receiver on , you meant the main switch in the back ... right ? and it will show the dash ?? right ? b/c the power buttonin the front doesn't work right now |
Gold Member Username: KirankumarI will not b... Post Number: 2103 Registered: Oct-07 | yes you got it from the back |
Bronze Member Username: Deptrai_cachonPost Number: 54 Registered: Jan-08 | ok thanks....i'll try it and keep you update. for all the people help me .. thank you very very much ... i thought my receiver is dead for good .. |
Gold Member Username: KirankumarI will not b... Post Number: 2105 Registered: Oct-07 | Ken, be patient and persistent,your receiver is NOT dead,do exactly as i have told you and you will get it working.good luck |
Bronze Member Username: Deptrai_cachonPost Number: 55 Registered: Jan-08 | anyone please help ....i try to load the factory bin using loader2 .. but it said the selected file not exeptable .. what's wrong ?? i used viewsat ultra v0132 |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 835 Registered: Jan-08 | Try VSPRO Loader - Firmware Updater ( Serial) From viewsatusa.com/support |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 836 Registered: Jan-08 | This is loader for Vspro but work fine for ultra. |
Bronze Member Username: Deptrai_cachonPost Number: 58 Registered: Jan-08 | that's what i used ....but when i pick the factory bin v0132 .. it said not exeptable what else can I do ? |
Bronze Member Username: Deptrai_cachonPost Number: 59 Registered: Jan-08 | yes, but it's not exepting the factory bin |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 845 Registered: Jan-08 | Ok Ken try to download last bin directly |
Bronze Member Username: Deptrai_cachonPost Number: 69 Registered: Jan-08 | African , the reason i was having problem lastnite with the loader because i was using loader1 . downloaded from viewsatusa.com ( it didn't work with vsultra) but i got the loader2 at ftatalk.com and it work .. my vs up and running !! |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 876 Registered: Jan-08 | Good news Ken |
Gold Member Username: KirankumarI will not b... Post Number: 2120 Registered: Oct-07 | I assumed you were using loader 2 as to your post, but i am glad you got it working ' enjoy Ken Bronze Member Username: Deptrai_cachon Post Number: 55 Registered: Jan-08 Posted on Thursday, March 13, 2008 - 08:47 pm: anyone please help ....i try to load the factory bin using loader2 .. but it said the selected file not exeptable .. what's wrong ?? i used viewsat ultra v0132 |
