Grounding dish and switch
Username: Cnn
Post Number: 20
How essential is grounding your dish and switch. I'm living in an apartment on the third floor, what is the recommended grounding when my superdish and dp34 switch located on the patio? Would running a wire from the switch the the patio metal fence/frame adequate?
Username: Kirankumar
I will not b...
Post Number: 2106
that should work
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 837
Dustin
Ground is need for static and interference, if dish is in lower position.
If hight position you must protect it for lighting flash(i dont know if good word)
that protect your equipment.
Username: Cnn
Post Number: 21
Thanks for the info. When I unplugged the coaxial cable going into the receiver, I can feel a good buzz on my hand when touching the tip of the coaxial cable, is this due to not grounding the DP34 switch? It never felt this strong current going thru the cable when I was using a SW21.
Username: Plymouth
Post Number: 847
Not supposed to make that, you have a ground problem on electric circuit
