Clifford Matrix RS question
Username: Mdconvert
Poolesville, MD
My son recently picked up a '94 integra that has a Clifford Martrix RS alarm in it. We didn't know the model so we went looking for the controller and found that it is a Matrix RS model.
When we put everything back together, the remote start is not working correctly. The starter runs, the engine runs (with the starter still running) for about 10 seconds, then everything shuts down and it repeats the cycle. I have a feeling that the tach signal isn't getting to the controller. Can anyone point me to information that tells me what wire to look for and where to attach it?
Also, where can I find an installation manual for this car?
Thank you in advance,
Username: Mdconvert
Poolesville, MD
A bit more information. After starting the car remotely, and while the starter is still turning - if I rev the car up slightly the starter stops running.
Is there some setting I need to change somewhere that tells the controller that a lower RPM is ok, and he can stop running the starter?
Thanks again,
Username: Mdconvert
Poolesville, MD
After receiving some information from Skater_Bum (http://www.directeddealers.com/manuals/ig/clifford/N909552.pdf) and then replacing a broken valet switch, I was able to have the system learn the proper RPM for the car.
Thank you Skater_Bum for all of your help.
Dan
