Silver Member Username: 94_toyPost Number: 171 Registered: Sep-07 | So wats the difference between the two: http://www.sonicelectronix.com/item_8632_Pioneer+Premier+TS-W1007D4.html http://www.sonicelectronix.com/item_8333_Pioneer+TS-W257D4.html is one a better sub then the other??, and can they handle a true 350W RMS or should i run less or more? |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 13358 Registered: Jul-05 | havent worked with the premier version but looking at both subs (12" versions) i really cant see any physical differences except T\S may slightly vary but nothing much to notice look at what the dual 2ohms 257 does <<<<<<<<< ...... |
Silver Member Username: 94_toyPost Number: 172 Registered: Sep-07 | yeah rovin thats why im lookin at the 257s for some cheap SPL. What do they got for sq, adn wat amp did u run them on>? nice score by the way for $49.99 each lol |
Platinum Member Username: Rovin4 10 Pioneer... Post Number: 13361 Registered: Jul-05 | i used a soundstream picasso 2000d - they took it without any problem.....they can handle 1.5 times rated power easily ..... this was mine : |
Gold Member Username: SomedonniedudeIllinois United States Post Number: 1172 Registered: May-07 | Rovin what's those boxes tuned to, and hows the sq? |
