Bronze Member Username: Bn1Post Number: 43 Registered: Jan-08 | Originally, i was going to go with the alpine buuuut.. i saw the kicker today for 265.. I was just curious as to if there is any reason for that amp to be so cheap like it just is not up to par...or if the site is just having a good deal on them right now.. http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16927 thanks for the help. |
Silver Member Username: Drant19DUB-C, TX Post Number: 443 Registered: Aug-07 | the alpine will have a smaller footprint than that kicker, however, the kicker will put out more power. no telling how much tho until you see a birthsheet |
Bronze Member Username: Bn1Post Number: 44 Registered: Jan-08 | footprint? |
Silver Member Username: Drant19DUB-C, TX Post Number: 445 Registered: Aug-07 | the size of the amp. |
Gold Member Username: Nd4spd18Northwest PA Post Number: 6723 Registered: Jul-06 | Quality wise, alpine. The kicker has more power though and is still very good. |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 5220 Registered: Dec-05 | depends... what are you trying to push? |
Bronze Member Username: Bn1Post Number: 45 Registered: Jan-08 | a cdt comp set .. maybe two of them ef61 and tw-25 tweeter i believe.. if not the second set then bridge 3 and 4 to run a sub |
Gold Member Username: JuliobSanto DomingoDominican Re... Post Number: 5223 Registered: Dec-05 | i'd recommend kicker zx just because you want to push a sub. |
Silver Member Username: Drant19DUB-C, TX Post Number: 462 Registered: Aug-07 | if your gonna get 1 set of comps and a sub then get 2 amps (1) 2channel - speakers (1) classD mono - sub |
