New member Username: OriginalfinchPost Number: 4 Registered: Mar-08 | Is this a decent amp??? I have the chance to buy this brand new for 300$, I am wanting to maybe match it up with a single alpine type x 10inch, or one of similar quality. How do you think it would work? http://www.alpine-usa.com/US-en/products/product.php?model=PDX-2.150&lang=en&tab =F |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1515 Registered: Mar-04 | It's a quaIity amp, but don't see the point in spending cvx money when you only have 300w. A type R will do just as well for half the price. |
Platinum Member Username: Chaunb3400All he does is catch t..., Alabama U.S. Post Number: 14051 Registered: Jul-05 | Very good amp, but i would look for anothe sub |
Silver Member Username: Drant19DUB-C, TX Post Number: 436 Registered: Aug-07 | if u want to run a sub, then get a mono amp. however u cant pass up the amp deal, then put it on some components |
Gold Member Username: N2audioLawrence, Ks USA Post Number: 1517 Registered: Mar-04 | the only advantage a mono amp has over a stereo amp (usually) is efficiency, but the pdx is class D and is very efficient. On top of that, at 300w the advantage class D has over class D is minimal anyway. The pdx150.2 is just as good as any other amp in powering a sub. |
Silver Member Username: Drant19DUB-C, TX Post Number: 438 Registered: Aug-07 | im just sayin that 300watts isnt enough for a type-x. i would just go a different route. but if he likes it then thats what matters |
New member Username: OriginalfinchPost Number: 6 Registered: Mar-08 | What about the 1000w pdx?!? I don't really know what is a good sub, I just know alpine is good and type x is highest quality in there line... i think |
New member Username: OriginalfinchPost Number: 7 Registered: Mar-08 | Thanks for all the help guys |
Silver Member Username: Drant19DUB-C, TX Post Number: 446 Registered: Aug-07 | how much are you looking to spend total? sub, amp, box? im sure we can figure something out. also what are you looking for ? SQ-sound quality SPL-loud SQL-mix of both |
