Bronze Member Username: MaxedoutPost Number: 15 Registered: Dec-06 | can i use a DTV36EDS to get channels on 118.7? thanks. |
Gold Member Username: KirankumarKenya Post Number: 2007 Registered: Oct-07 | Max, what is this DTV36EDS |
Gold Member Username: RtapFL Post Number: 1984 Registered: Jan-07 | heres what it is DIRECTV DTV36EDS INTERNATIONAL SATELLITE DISH *NEW* DirecTV DTV36EDS ( 95, 101) # DirecTV 36" International Dish (87CM) # For International / Ethnic DirecTV Programming # Includes (1) DTV36EDS WorldDirect International Dish # Includes (1) Required LNB for 95 WL Satellite # Includes (1) Required LNB for 101 Satellite # Includes (1) Required Bracket to hold 101 and 95 LNBs # Includes (1) Required Universal Mounting Bracket # Includes (1) Easy to use Instructions # Zinwell 4x4 Multi-Switch Included |
Bronze Member Username: BanglePost Number: 34 Registered: Jan-08 | as far as i know the dish 1000 has the 119 LNB point to the echo7 and anik bird too. I dont think the DTV dish can do that. |
Bronze Member Username: MaxedoutPost Number: 16 Registered: Dec-06 | but can't i just point the dish to 119 and use the DT36EDS lnbs to get 118.7? |
Gold Member Username: KirankumarKenya Post Number: 2009 Registered: Oct-07 | Max if you have the dish then go ahead and give it a try,no harm in that |
Gold Member Username: RtapFL Post Number: 1991 Registered: Jan-07 | AFRICAN is right.the way we learn is by trial and error. |
Bronze Member Username: MaxedoutPost Number: 17 Registered: Dec-06 | i'm planning on buying this dish but want to make sure i could get 118.7 with this dish. |
Gold Member Username: NydasPost Number: 8892 Registered: Jun-06 | Seeing is belieing, and without trying you won't see. In a general way, I can say that the 118.7 signals are weaker than 119, but I don't see why a good 36" dish can't be used though it was designed for something else. Make sure you buy a 118.7/119 specific Universal LNB. |
Platinum Member Username: LklivesPost Number: 14328 Registered: Jan-06 | LMAO...that dish is 100% useless for ya, for DN and the 118... |
Gold Member Username: NydasPost Number: 8896 Registered: Jun-06 | The generic $20 Universal LNBs are working well with 30" ordinary dishes. The 36" dish will work too. |
Platinum Member Username: LklivesPost Number: 14331 Registered: Jan-06 | Dish 300 Single slot 18" round DBS dish that can pick up programming from one DBS satellite location at a time. DBS locations for Dish are 61.5°, 110°, 119°, 129°, 148° and (not used) 157°. Dish 500 A two slot 18" x 20" DBS dish designed to pick up 110° and 119° simultaneously. However it can be used to pick up 119° and 129° or just one satellite location like 61.5° or 148°. Dish 1000 A three slot DBS dish designed to pick up 110°, 119° and 129° simultaneously. This dish can be used to pick up 129° and 148° simultaneously. Dish 1000.2 Slightly larger than a Dish 1000, its integrated head unit has 3 LNBs (110°, 119° and 129°), an input for a 4th LNB, and DP Plus switching to 3 receiver outputs. Plus Dish 500+/1000+ Same as the Dish 1000 in function but about 5" larger and can pick up the 118.75° FSS location. As a 500+ it picks up 110°, 118.75° and 119°. Adding an LNB for 129° makes it a 1000+. SuperDISH 105: Specifically designed to pick up 105°, 110° and 119° 121: Specifically designed to pick up 110°, 119° and 121° Dish Size Mast Use Alternate Dish 300 18" round 1-5/8" One DBS slot Dish 500 20"w x 22.5"h 1-5/8" 110° & 119° One DBS slot, 119° & 129° Dish 1000 23"w x 18"h 1-5/8" 110°, 119°, 129° Dish 1000.2 25.9"w x 20.7"h 1-5/8" 110°, 119°, 129° Input for 4th slot Plus Dish 30.9"w x 23.8"h 1-5/8" 110°, 118.75°, 119° Add 129° SuperDISH 33.3"w x 24"h I: 2"II: 2-3/8" 105°, 110°, 119°..110°, 119°, 121° |
Gold Member Username: NydasPost Number: 8899 Registered: Jun-06 | Useless information. The client wants to know if the 36" dish will work if he anted to use a Universal LNB designed for 118/119W and I am saying there is no reason why it should not. |
Platinum Member Username: LklivesPost Number: 14332 Registered: Jan-06 | U better learn to read azzhole.. NEVER does he ask that or anything about a universal LNB...just asked if he could use this dish which comes with 101 and 95 LNB's... AGAIN...U provide BOGUS info! |
Gold Member Username: NydasPost Number: 8901 Registered: Jun-06 | LK: Whilst you are attemPting to discredit me (in which you will never succeed) a complete novice by the name of Plymouth has discovered a solution to Viewsat freezing. YOU ARE A LOST PUPPY. |
Gold Member Username: NydasPost Number: 8904 Registered: Jun-06 | Plymouth: What do we say in French? |
Platinum Member Username: LklivesPost Number: 14335 Registered: Jan-06 | U are a complete novice ...trying to change the topic and hijack the thread away from your BOGUS postings again...which are daily with you.. |
Gold Member Username: NydasPost Number: 8907 Registered: Jun-06 | LK: You don't know what you are talking about. Go and take your medications. |
Bronze Member Username: MaxedoutPost Number: 18 Registered: Dec-06 | thanks guys, i guess i'm not going to take chances buying a dtv36eds. so will a dish 1000 get 118.7? |
Gold Member Username: NydasPost Number: 8971 Registered: Jun-06 | You will still need the special Universal LNB |
Platinum Member Username: LklivesPost Number: 14392 Registered: Jan-06 | No U won't...get the dish 500 PLUS...or the 1000 PLUS...they come with it, the 118....nalins an azzhole...again posting bogus info... |
Gold Member Username: NydasPost Number: 8979 Registered: Jun-06 | Max Edout : LK has to contradict me. Just talk with DN people and ask them. |
Platinum Member Username: LklivesPost Number: 14393 Registered: Jan-06 | Plus Dish 500+/1000+ Same as the Dish 1000 in function but about 5" larger and can pick up the 118.75° FSS location. As a 500+ it picks up 110°, 118.75° and 119° |
Silver Member Username: AbjPost Number: 534 Registered: Feb-06 | Circular Dual LNB for both 119 & 118.8°W [118-119lnb] It's a brand new Ku Band Circular Dual output LNB with Dual polarization. It's designed especially for catching 119 & 118.7 /118.8(Anik F3) at the same time using one such LNB. Each Output gives signal from both satellites. Features: * Dual Output; Neck size: 40mm * Input Frequency Range from 11.70Ghz ~ 12.75Ghz * Output Frequency Range from 950Mhz ~ 2150Mhz * ROC Brand; L.O. figure: 10.75Ghz; * Extremely Low Noise Figure: 0.3dB * Low Phase Noise for Analog or Digital reception * Brand new CB2008A type with Excellent stability * Best solution for individual and multi-satellite systems * Weather-proof O-Ring and Gasket inside. ATTENTION Requires: 30-inch or larger dish Compatible with DirecTV, Free-to-Air (DiSEqC, 22KHz), and legacy switches (SW21, SW44, etc) Not compatible with DishPro switches and/or DishPro (stacked) LNB's Instructions Using a 30-inch or larger dish (we recommend 33-inch), aim with the following settings: Satellite Name: 118°W (Anik F3) or 119°W (Echo7) LNB Type: Standard (or Single) LO Frequency: 10750 or 10600 MHz Finally, do an AUTO SCAN or a BLIND SCAN For some the following settings may work better or give you more channels: LNB Type: Universal If your missing any channels, manually scan them. You can refer to www.lyngsat. _ _ _ / www.lyngsat*com/anikf3.html LO Frequency: 9750 MHz HI Frequency: 11250 MHz Make sure Anik-F3 (118.7°) TP figure in your receiver menu is correct. |
Platinum Member Username: LklivesPost Number: 14398 Registered: Jan-06 | in fact DN is going to all their subscribers and changing out the dishes for them ...not just adding LNB for the 118... |
Gold Member Username: NydasPost Number: 8982 Registered: Jun-06 | Ask DN. Don;t ask LK. She could have told you all this before if she knew anything. Justice is good and OK. You can trust him. |
Silver Member Username: Madflea168Post Number: 321 Registered: Jan-08 | there is repoint kit for converting superdish to 500+ or 1000+, 500+ gives you 110/118/119 and 1000+ will add 148 to it. I don't believed the regular 1000 will do the job. |
Silver Member Username: Madflea168Post Number: 322 Registered: Jan-08 | sorry, my bad, not add 148, it is 129. |
Platinum Member Username: LklivesPost Number: 14409 Registered: Jan-06 | get a dish 500 PLUS this is the LNB U need, if ya alter another dish,, CB 2008 LNB for the 118 http://chicago.craigslist.org/wcl/ele/599142789.html http://www.alibaba.com/catalog/100334796/Circular_91_118_119_Satellite_Dish_Twin _Lnb_Lnbf_Cb2008.html http://www.alibaba.com/catalog/100334775/Circular_Dual_Lnb_Lnbf_For_Dish_Net_Bel l_Bev_Vu_Cb2008a.html http://www.sindaltech.com/lnbcb2008.htm |
Platinum Member Username: LklivesPost Number: 14412 Registered: Jan-06 | and here's a bunch of Dish 500 Plus from Ebay... http://search.ebay.com/dish-500-plus or here from sadoun...reputable dealer.. http://www.sadoun.com/Sat/Products/Dishnetwork/Dishes/Dish-500-Plus-Dish500Plus.htm http://www.sadoun.com/Sat/Products/Dishnetwork/Dishes/Quick_Facts_-_DISH_500+_and_DISH_1000+[2].pdf OVERVIEW DISH 500+ receives signal from 110°, 118.7°, and 119° orbital locations DISH 1000+ receives signal from 110°, 118.7°, 119° and 129° orbital locations. Uses DISH Pro Technology INTRODUCTION DISH 500+ receives signal from the 110°, 118.7°, and 119° orbital locations. An optional LNBF and bracket can be attached to upgrade the DISH 500+ to a DISH 1000+, which adds reception from the 129° orbital location. EQUIPMENT The 500+ Antenna Kit includes the dish, backing assembly, feed arm and Installation Instructions for installing the DISH 500+ and 1000+. If needed, a kit including the mast, foot, and a set of struts is available separately. The LNBF kit* for DISH 500+ and DISH 1000+ includes the DP 500+ LNBF Assembly, and a bracket used to upgrade a DISH 500+ to a DISH 1000+. DP 500+ LNBF ASSEMBLY The DP 500+ LNBF Assembly includes two LNBFs. An FSS/DBS Dual Band LNBF receives signal from 119° and 118.7°, while 110° is received by a separate DISH Pro Dual (or DP Single) LNBF. A DISH Pro 34 (DP34) or DISH Pro Plus 44 (DPP 44) switch can used with the DISH 500+. http://www.sadoun.com/Sat/Order/Dishes/Dish-Network-Satellite-Dish.htm Dish Network DISH 500 Plus Antenna (For Dish Network regular programming, HDTV, international, and some local channels). This satellite dish is used by Dish Network to receive signal from 3 orbital locations (110,118.7,119). Box Includes: Dish500+ 23.8"h x 30.9"w dish DP Dual Band LNBF for orbital locations; 118.7°, 119° DP Single LNBF 110° Mounting bracket for the optional 129° LNB is included. Universal mount: lets you put the dish on your roof or exterior wall of your house. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 2567 Registered: Oct-06 | That dish and that LNB Should be able to pickup 118.7 Polarity of that LNB is the tricky part But should work It also depends on what receiver yo got And setting correct LNB Voltage and freq I would love to get my hands on that dish and LNB That's a great 36" dish Just change the LNB to get 118.7 if it doesn't pickup Sat If yo didn't buy it yet Buy a super dish much less headache |
Platinum Member Username: LklivesPost Number: 14413 Registered: Jan-06 | Just buy a Dish 500 PLUS...lets not reinvent the wheel.. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 2568 Registered: Oct-06 | Very few dish 500 plus available to buy now days Many people get confused with dish 500 with dishpro plus LNB And for some reason super dish is very cheap now I also noticed DN new installations uses super dish only They still call it dish 500 plus for 110/118/119 And dish 1000 plus for 110/118/119/129 For both cases they install super dish for all new subscribers |
Silver Member Username: MuchoPost Number: 105 Registered: Dec-07 | Justice you say that you can scan both 119 and 118.7/118.8 (Anik F3) at the same time. How can that be? Don't you need to scan one at a time? When I scan Echo 3 @ 61.5 or Rainbow 1 @ 61.5 both at the same orbit,then why do I have to scan each separately? My receiver don't even list Anik F3.I need to enter this birds and the TPs. |
Platinum Member Username: LklivesPost Number: 14420 Registered: Jan-06 | To add Anik F3 Antenna Setup A) Scroll to Edit TP/Satellite press (OK) B) Scroll to bottom you will see the word NEW press (OK) C) On this board highlite one character at a time and press (OK) when you finish entering these characters, if it looks like this Anik F3/Ku ..press (OK)should be at the bottom next to del. next you will see this. Down Frequency Symbol Rate Polarity Pull up.....http://www.lyngsat.com/anikf3.html here you will find all the TPs for Anik F3. If you don't have a HD Receiver don't bother entering the TPs outline in green. I will post the first TP for you. Down Frequency....11715 Symbol Rate...20,000 Polarity V yes its circular polarity with a 10750 freq.. |
Gold Member Username: TapemanNew York City in-HD, NY Post Number: 2569 Registered: Oct-06 | Mucho 61.5 Rainbow and 61.5 Echo-3 Identical TPs Slight freq difference This is where N2 and N3 lingures Name don't matter Yo can call it Yukon if yo want It's all about freq and Tps now 118.7 and 119 to provide continues freq span Even if they are coming from 3 different sats It's all about freq and Tps now |
Bronze Member Username: MaxedoutPost Number: 19 Registered: Dec-06 | thanks everyone, i just purchased a brand new superdish. hope i made the right choice. |
Platinum Member Username: LklivesPost Number: 14438 Registered: Jan-06 | SuperDISH 105: Specifically designed to pick up 105°, 110° and 119° 121: Specifically designed to pick up 110°, 119° and 121° I thought U wanted the 118...now U got to alter the dish and buy another LNB....U should have bought the Dish 5000 PLUS, like I said.. |
Gold Member Username: NydasPost Number: 8991 Registered: Jun-06 | Any dish that is over 30" wide and can scan 119 WILL scan 118.7 easily with a special Universal LNB. If you wish to learn, LEARN, OTHERWISE KEEP QUIET |
Platinum Member Username: LklivesPost Number: 14445 Registered: Jan-06 | U know nothing about the 118...and contributed nothing here to help...but I did! |
Gold Member Username: NydasPost Number: 9005 Registered: Jun-06 | IDIOT LK COPIES SOMEBODY ELSE'S WORK AND WANT TO TAKE CREDIT. FAIL.....0/10 |
Bronze Member Username: MaxedoutPost Number: 20 Registered: Dec-06 | thanks LK and Nalin but i came to my decision after a conversation with charlie. he told me that i would need at least a 30" dish or larger and a circular lnb, which i will attach with zip ties to the 119 lnb of the superdish. |
Gold Member Username: NydasPost Number: 9051 Registered: Jun-06 | That is not any different from what I said yesterday. "Any dish that is over 30" wide and can scan 119 WILL scan 118.7 easily with a special Universal LNB. " |
Platinum Member Username: LklivesPost Number: 14471 Registered: Jan-06 | Charlie is an idiot if that's what he told you...which I do not beleive 1 word of that.....Charlie knows MUCH better than to tell U to make a poormans dish...while Charlie has a specific Dish 500 PLUS for the 110-118-119...or the Dish 1000 Plus U must think we're all retarded , like nalin... who are U kidding Max? ...aka whoever u really are.. |
Gold Member Username: NydasPost Number: 9058 Registered: Jun-06 | Max: Charlie knows his Dishes and Sats and LNBs much much better than LK or I do. Happy viewing. If you have problems, address your questions to "Mad Flea" in this forum. |
Bronze Member Username: MaxedoutPost Number: 21 Registered: Dec-06 | LK: do you know who i'm talking about when i'm saying Charlie? i think you're the only retard than from that last comment you made. Charlie is DN. you see this how you manage to piss people off with those wise remarks. |
Platinum Member Username: LklivesPost Number: 14476 Registered: Jan-06 | Charlie = Dishnetwork employees ...mostly 18-22 yr old stupid kids working in custommer service...reading off a pre written script Mav.,..U don't want to fuuccck with me kid!..I honestly have forgotten more than U will ever know about satellites and DSS....go play HERO with your lil 14 yr old buds about how u get free TV.. and U made a real BONEHEAD move with that dish...so don't comeback and ask 1 million stupid questions cause U ignored good advice kid.. |
Gold Member Username: NydasPost Number: 9069 Registered: Jun-06 | Max Edout : The best thing that can happen to you is LK refusing to help. Then we can get along with real work. You look at what Charlie is suggesting. It will probably be a special kit about $110 to switch from 121 to 118.7 Or you can get the special LNB designed for getting 118.7 and 119. Just Google 118/119 and you will get two or three varieties. Mad Flea here and African will both be able to help you |
Platinum Member Username: LklivesPost Number: 14483 Registered: Jan-06 | Max...don't come crying when Nalin and Charlie come with a warrant... |
Gold Member Username: NydasPost Number: 9079 Registered: Jun-06 | Don't worry about warrants. The only warrant likely is to arrest LK for her part in ftaprosupport fraud. Just ask Mad Flea what to do. |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 758 Registered: Jan-08 | Plymouth Silver Member Username: Plymouth Quebec city , Quebec Canada Post Number: 755 Registered: Jan-08 Posted on Monday, March 10, 2008 - 07:48 pm: -------------------------------------------------------------------------------- LK your courtesy choke nobody. Now sorry but, i really think, you are a idiot who work for Dn, all who work, all help disturb you. You escape directly of a asile. Now and well listen that, for me the winner is Nalin Nyda Nalin you may use how you went I repeat again enough is enough Never Nalin attack me LK You are a idiot Thanks |
Bronze Member Username: MaxedoutPost Number: 22 Registered: Dec-06 | thanks guys. do i really need a special circular lnb to get 118.7, when 110 and 119 are circular? correct me if i'm wrong, but on lyngsat under the first column labeled as "Freq. Tp" "R" = right-hand and "L" = left-hand mean they are circular polarizations. and "V" = vertical and "H" = horizontal mean they are linear polarizations. thanks. |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 777 Registered: Jan-08 | Max linear is vertical and horizontal circular is left and right This LNB is oval on is width and standard is round, that why it can catch 0.25 degree. |
Bronze Member Username: MaxedoutPost Number: 23 Registered: Dec-06 | thanks Plymouth, that explains why i can't use the exisiting lnb off my 61.5 dish or the 119 lnb to catch 118.7. |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 778 Registered: Jan-08 | Max it's 1.25 degree You may use the same like me, but when we scan, we catch channel on 2 sat with bad signal. It's better with |
Gold Member Username: NydasPost Number: 9112 Registered: Jun-06 | Max: There are people who have received 118.7 signals with both Linear and circular LNBs. You get a 4 DB drop., and might miss several channels. The main point is that all of internationals on 121 are moving to 118.7. There is a possibility of 61.5W and 148W internationals being phased out. - No confirmations of this. You might as well do a good job and use a special Universal LNB designed specifically for the 118/119. The LNB is about $18 to $25. With a bit of effort you will get going nicely. Alternatively you can get the full 121 to 118.7 conversion kit for about $110 directly from DN. Either way you will be a winner. |
Gold Member Username: NydasPost Number: 9122 Registered: Jun-06 | CIRCULAR DUAL LNB LNBF CB2008A FTA 118.7 DISH 119 118.8 It's designed especially for catching 119 & 118.7 (Anik F3) at the same time using one such LNB. Each Output gives signal from both satellites |
