Need help with an amp
Username: Blaaaahhhhh
Warrior, Alabama Usa
Post Number: 46
i need an amp that pushes at least 2500rms to power a 2 ohm comp. cerwin vega 12. ive been lookin and im having a bit of trouble. please help
Username: Drant19
DUB-C, TX
Post Number: 457
kicker zx2500.1
Post Number: 47
I don't have that kinda money but can't you run 2 amps to one sub?}
Username: Nd4spd18
Northwest PA
Post Number: 6762
If the sub is DVC, has the correct coils and the amps are strappable.
ZX2500.1 is the best option for 2500w at 2 ohm though.
Post Number: 48
Ok well I can't find that amp for cheaper than 700 and I don't have that kinda money, what kinda coils do they have to be? because it is a dvc sub}
Username: Nd4spd18
Northwest PA
Post Number: 6771
You can get that amp for $540. Cheaper if you get a used on on caraudio.com.
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/3175007/vpcsid/0 /SFV/30046
One big amp will be cheaper than 2 smaller amps.
Username: Drant19
DUB-C, TX
Post Number: 458
do you have the electrical upgrades needed to run that kind of power?
Post Number: 49
I hope so, its just gonna be that single sub and I'm gettin an h/o altenator and prolly a really big capacitor}
Username: Nd4spd18
Northwest PA
Post Number: 6775
No capicator. HO alt and big 3.
Post Number: 50
Big 3?}
Username: 04redmach1
Lagrange, GA USA
Post Number: 1669
So is your sub a dual 2 ohm sub? If so, what is your budget for amp?
Kevin
Post Number: 51
It is 2 ohm and I really don't wanna spend more than $400}
Username: Nd4spd18
Northwest PA
Post Number: 6781
Wait your sub is DUAL 2 ohm???????? Then you need a 1 ohm amp.
Post Number: 52
Yeah }}
Username: Nd4spd18
Northwest PA
Post Number: 6788
Audioque 2200D $389
Username: Juliob
Santo DomingoDominican Re...
Post Number: 5222
HO alt and a good front battery, like kinetic IMO.
Username: Loudazzaltima
Brooklyn, NY
Post Number: 11
I think orion has a amp that can suit ur needs
