I'm trying to add a proximity sensor to my Clifford concept 500 system.
I have taken the earth & 12v feed's to it, but it also has two wires, one for the 'warn away' and one for the 'full trigger' basically the two zones that the proximity sensor covers.
I have tried to wire the two wires(which can be put together on certain systems, not sure if mine is) to the blue/white wire on the clifford which is for the additional proximity sensor.
But :wonder:
it doesnt trigger the alarm, nor does it chirp for a warn away.
How should i connect the proximity to the clifford please?
