Username: Lklives Post Number: 14452 Registered: Jan-06
Sunday, March 09, 2008 - 22:49 GMT Thread: FTA 101....rule #1 and #2....#3...#4 WRITE down and SAVE the antenna/dish settings is the #1 rule of FTA...followed closely by rule #2 , which is ALWAYS do a REBOOT before and after a bin upload, or whenever U have ANY problem... Most problems are due to INCORRECT, and not written and saved, ANTENNA SETTINGS ...which if written down and saved, will take 30 seconds to reinput into your receiver....menu-installation-antenna settings Most problems can be resolved with a simple REBOOT ( using rear switch, power OFF for 2-3 minutes, then power back ON)..I suggest u do this both BEFORE and AFTER U upload any new file.. Regarding ANTENNA SETTINGS...Simply put, your receiver has no clue what satellites, LNB's, frequencies, switches, switch ports etc, that U have on the dish and roof...so it doesn't know whats going on, and what U did with the hardware up there....so U must tell it, by going up on the roof (bring paper and pen) and looking at your hardware and cables and switches etc and WRITE them down...then U come back to the receiver and input the corresponding info (antenna settings)...so now your receiver understands what ya did and can work correctly...WRITE these down, unless u like climbing on the roof all the time...these antenna settings will often change by themselves, especially after uploading a new file/bin.. BTW...there is NO "1 shoe fits all" ANTENNA SETTINGS...each house, dish, LNB's, cables, switches, switch ports used, are different.. So don't expect other peoples settings to work for you..that will ONLY happen, IF co-incidentially they have the exact same LNB's , switch ports etc and all cabled and combined exactly as you, which is very unlikely.. Antenna Settings Sat Degree(s) ----------->> lnb type------------------>> local freq----------------->> local freq (low) ---------->> diseqc ver --------------->> diseqc ------------------->> 22 KHZ ------------------>> multi-switch ------------>> #3....NEVER HIJACK A THREAD..just to bash others or post useless info #4...IGNORE the hijackers who's sole intention is draw attention to themselves and destroy FTA...there are Charlie moles here, one who is especially well known for this..
Username: Nydas Post Number: 9018 Registered: Jun-06
Sunday, March 09, 2008 - 22:54 GMT Master Password Acc..........................: 0786 Akai.........................: 9009 Amstrad SilverLine...........: 3472 Amstrad CromLine.............: 0000 Ariza........................: 0786 Asterix/Digibox..............: 8175 Astra 3472...................: 6789, 9876 Astrovox.....................: 1668, 1010 Aztech ......................: 1004, 1111 Amstrad Silverline...........: 3472 Amstrad Cromline.............: 0000 Baff.........................: 2142 Baftec 8008 Dragon...........: 1668 Benjamin.....................: 1004, 1250 Besat........................: 8175 Bluejay......................: 3742 Botek........................: 5183 Botech 2000-2001 ci..........: 4200 Captive Works ????.. 9876 Citizen......................: 7604 Coo*lsat......................: 0103 Daewoo.......................: 8503 Digimaster 4100 FTA..........: 2606 Digimaster 4200 FTA..........: 2606 Digimaster 4300 CI...........: 2606 Digimaster 4400 CIP..........: 2606 Digital and QMax.............: 0325, 0867, 0876 Digital Telecom..............: 0851, 1004, 3472 Digitel......................: 0867, 0786 Digiwave ??.. 1004 Dizipia......................: 2142 Druck........................: 1324, 1424, 1524, 1624 DV...........................: 8503 DWay.........................: 8503 Echostar.....................: 7604, 2441, 3604 EchoStar.....................: 3453 EchoStar 2200-1200...........: 7604 EchoStar 2110................: 3453 Emtech/Jesspen...............: Menu, Installation OK, STB, OK, 9876 Euromax Em 5000/7000CI.......: 2142 Eurostar.....................: 9999 Euro Star....................: 9949 EuroStar / UroBox............: Menu Key, Enter 9999 And OK. Press 0000 And OK. Now Changed To 0000. Fortec Star 5100PLUS.........: 1010, 1668, 1002, 1111 Fortec Star LiFETIME.........: 1010, 1012, 9966, 6699, 0000, FOrtec Star..................: 1002, 2228, 2002, 2004 Fortec Star 6000.............: 1002 Fortecstar Oneworld..........: 0914 Galaxis......................: 9949 Galaxy.......................: 9949 Golden Interstar.............: 2142 Goldmaster SAT-60100.........: 3453 Goldmaster SAT-60500.........: 3453 Goldmaster SAT-70500.........: 3453 Goldmaster SAT-70700.........: 3453 Goldmaster SAT-80100.........: 3453 Goldmaster SAT-80300.........: 3453 Goldmaster SAT-80500.........: 3453 Goldmaster SAT-80700.........: 3453 Goldmaster SAT-80900.........: 3453 Goldmaster SAT-90200.........: 3453 Goldmaster SAT-90400.........: 3453 Goldmaster SAT-7200 FTA......: 2606 Goldmaster SAT-7300 CI.......: 2606 Goldmaster SAT-7400 CIM......: 2606 Goldmaster SAT-7800 PVR......: 2606 Goldmaster SAT-4150 FTA......: 2606 Goldmaster SAT-4100 FTA......: 2606 Goldmaster SAT-4800 PVR......: 2606 Goldmaster SAT-9200..........: 2606 Goldmaster SAT-9400 CI.......: 2606 Goldmaster SAT-9500 CIM......: 2606 Goldmaster SAT-9600 CIP......: 2606 Goldmaster SAT-9800 PVR......: 2606 Goldmaster SAT-9900 PVR......: 2606 Goldmaster SAT-8150 FTA......: 3141 Goldmaster SAT-8200 FTA......: 3141 Goldmaster SAT-8210..........: 3141 Goldmaster SAT-8300 CI.......: 3141 Goldmaster SAT-8350 CI.......: 3141 Goldmaster SAT-8400 CIM......: 3141 Goldmaster SAT-10200.........: 3141-9247 Goldmaster SAT-10210.........: 3141 Goldmaster SAT-11300 CI......: 9247 Goldmaster SAT-11400 CIM.....: 9247 Goldmaster SAT-15400 CIM.....: 9247 Goldmaster SAT-16000 ........: 1600 Goldmaster SAT-16300.........: 1600 Goldmaster SAT-16500.........: 1600 Goldmaster SAT-17000.........: 1700 Humax 5400 Master Code.......: Press the menu and go to installation menu and press red key & green key & yellow key & blue key & white key and 0 Now Pin code changed to 0000. HUMAX F1-C1..................: Menu - status - STB Status - ok -press UP button at the Front panel - i - press the button contain ( ? ) press yellow button - exit now your Receiver return to 0000 Hyundai......................: 0325, 6962 Hyundai 1100 MCOM............: 1004 Kaon.........................: Left to Right press Red, Green, Blue and Yellow buttons Kaon.........................: Press Yellow key, Enter 0000 Press Blue 2 times, Press Green 2 times, Press Red 2 times, Press Menu key. Kaon.........................: Yellow, Blue, Green, Menu Kyoto........................: 3453 Lazer........................: 3141 Lorans.......................: 1250 Magnum.......................1818 Mediacom MFT 930I............: 5347 Mediacom MFT 910I............: 1250 Mediacom EXEL................: 1250 Mediacom MCI Elite...........: 7777 Metabox 1-2-3................: 1004 Megastar 700 FTA.............: 2606, 3141 Megastar 800 CI..............: 2606 Megastar 800 CIM.............: 2606 Megastar 700 FTA.............: 3141 Natvision....................: 1668, 1010 Neosat.......................: 1631, 6805 Neosat Old SX 9600...........: 3472, 3478 Neosat SX-9800CI.............: 2580, 3842 Neosat New 9600..............: 8510 Neosat 9800I.................: 2142 Neosat 9800CI (old)..........: 8510 Neosat.......................: 1631, 6805 Next Wawe....................: 8503 Next 8000xcam................: 4132 Next gri seri................: 0000 Next plus serisi.............: 8503 Next 5000 serisi.............: 1234, 1004 Next siyah seri..............: 0000 Next 3000A...................: 0000 Next 3000AP..................: 0000 Next 1000 (STAR1 )...........: 5183 Next 10001 PLUS:.............: 3453 New QMA X....................: 0325, 0867, 0876 Nokia 9800-9860..............: 1234 Nokia 9200...................: 147258 Nokia 9600...................: 1234 Oliverstar...................: Press The Menu Key And ENTER 9999, Press OK. Onwa X2 FTA..................: 3141 Onwa X3 FTA..................: 2606 Onwa X4......................: 3141 Onwa X5 CI...................: 2606 Onwa X7 CIM..................: 2606 Onwa X9 PVR..................: 2606 Onwa X2 FTA..................: 3141 Onwa X6 CI...................: 3141 Onwa X13 CIM.................: 3141 Onwa X23 CIM.................: 3141 Opensky......................: 0786 Opentel......................: 0937, 3472 Pace.........................: 9949 Pansat.......................: 1668, 1010 Pengamin.....................: 1250 Radix........................: 9815 Redliner 9500 CI.............: 1001 Roadmaster...................: 7787 Samsat.......................: 0937 Samsung.... .................: 0235, 7777 Samsung 702..................: 9911 Samsung 202 SVACI............: 1631 Samsung Model DSR 2000.......: Press Menu Key, Go To System Setup And Go To System Information, Enter 0000. SanyoSat 5400-5700-7000......: 3472, 2374, 3724, 1250, 6893 SanyoSat Viaccess............: 7176, 2606, 1470, 2441 SanyoSat (Plus) 5000-9000....: 2606 Satcruiser...................: 3742 Sky X........................: 0103, 1004 Smart........................: 3472, 6934 Spark 1100...................: 1004 Spark 3000 Magic.............: 2441 StarPro......................: 5889 Starsat......................: 1234, 1361, 1999, 9876 Startrack....................: 0786 Strong.......................: 0235, 0325, 1361, 0735 Strong FreeCam...............: 0235, 0735 Sunny........................: 2580, 7777 Sunsui.......................: 0937 Super Lazer 20000/1000.......: 2142 SuperMax.....................: 8503 Superstar....................: 2142 Taplin.......................: 3453 TechnoSat....................: 3724, 2374, 7176, 2606, 1470, 2441, 3724, 1250, 6893 Teleman......................: 7176, 1973 Tokyo........................: 3472 Topfield.....................: 2999, 2606 Topfield 3100 FEI............: 2606 Topfield 3000 CIPRO..........: 2606 Topfield 3000 CIPPRO.........: 2606 Topfield 3100 CIPPRO.........: 2606 Topfield 3100 FI.............: 2606 Topfield 3100 FE.............: 2606 Topfield 3300 F..............: 2606 Topfield 3030 F..............: 2606 Topfield 4000 PVR............: 2606 Topfield 5000 PVR............: 2606 Topfield 5300 CI.............: 2606 Toshiba......................: 1048 Urobox.......................: 9999 Vestel.......................: 8277, 929526 Viewsat......................: 0937, 3570 Viva.........................: 0786 Vortec.......................: 2002, 7777 Wisplus......................: 5030 YuMaTu x-200.................: 8888 YuMaTu 9500..................: 8503 YuMaTu 5500-8000.............: 2441 Zinwell......................: 8888
