CANNOT CHANGE CHANNELS ON VS ULTRA HELP
Username: Harchi777
Surrey, Bc Canada
Post Number: 31
From last two days my vs ultra gets stuck on one channel(working),and cannot change the channels.then i switch of from backside and after on ,i can change the channels.
pl help
Username: Way2smart
Www.Desifta.com
Post Number: 1384
Here folow these steps to change channels again....
_____________________________________________________________
Plymouth
Username: Plymouth
Quebec city , Quebec Canada Post Number: 693
Posted on Friday, March 07, 2008 - 10:05 pm:
Go to Code menu
Nagra and on Dish 01 06 00 Dish 00 01 00 dish 01 01 00
Delete this 3 provider with F3
switch off 10 secs on back panel
and load last bin
turn autoroll on
Thats erase bad data in the box
ENJOY TV
TESTED and work fine
New issue for problem on Viewsat
Thanks
Username: Kirankumar
I will not b...
Post Number: 2057
$mart,
sorry to interrupt but i don't recommend what you are saying,because there is a problem with the current bin and remote freezes every 7 to 8 hours,just do a hard reboot,because with your method the problem exists,why go through the hassle?
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 744
It's better to make it, but effectivly not resolve problem with remote and display freeze.
Username: Harchi777
Surrey, Bc Canada
Post Number: 32
anyways ,thanx dear
