New member Username: AnandoPost Number: 1 Registered: Mar-08 | my first post. I am able to get star one on 61.5 TP: 12414 VID: 4898 AUD: 4899 PCR: 4898 enjoy while new bins are out |
Gold Member Username: Saqeeb9000Mughe dard rehta hai, ..., Mujhe bhook ... Post Number: 2671 Registered: Oct-07 | any luck for 148 dish... |
Gold Member Username: NydasPost Number: 8679 Registered: Jun-06 | Confirming Star Plus at TP 12414 - Echo 3 (61.5) on Pansat 2500/FLU conversion TP: 12414 VID: 4898 AUD: 4899 PCR: 4898 |
Bronze Member Username: MriazPost Number: 74 Registered: Dec-07 | How you get TP: 12414 please |
Gold Member Username: NydasPost Number: 8680 Registered: Jun-06 | Riaz:Read this thread https://www.ecoustics.com/electronics/forum/home-video/452768.html The only thing different now is the new V-A and P posted above. |
Silver Member Username: VspPost Number: 249 Registered: Jun-06 | Nalin its Star ONE |
Gold Member Username: Saqeeb9000Mughe dard rehta hai, ..., Mujhe bhook ... Post Number: 2672 Registered: Oct-07 | so know is it different channel or same channel? |
Bronze Member Username: SatchatPost Number: 13 Registered: Feb-08 | Confirming Star One on Pansat 3500 - Echo 3 (61.5) Menu->Installation->Advanced Scan->12414 Mhz, 20.000 VID - 4898 AUD - 4899 PCR - 4898 Hit OK -> Ch-A ... which you can rename it as Star One Thanks |
Gold Member Username: NydasPost Number: 8687 Registered: Jun-06 | It is Star One. Anyway for many "Something is better than Nothing." |
Silver Member Username: VspPost Number: 250 Registered: Jun-06 | thats true nalin |
Bronze Member Username: Jaz06Post Number: 85 Registered: Nov-06 | confirm working on viewsat ultra dn |
Silver Member Username: Bazuka2020Post Number: 581 Registered: Oct-05 | For pansat 2700 go to Installation advance scan left click on tp until you get 12414 go to channel and hit enter and name you like input from numeric key pad VID AUD and PCR as above hit enter |
Bronze Member Username: DishallPost Number: 53 Registered: Dec-05 | any help how to go these settings in cw 600p, thank you |
New member Username: Teehee123Post Number: 10 Registered: Jan-08 | works on viewsat xtreme Great job guys =) |
Bronze Member Username: Kishan2006Post Number: 16 Registered: Jul-06 | confirmed working for koolsat 5000 |
Bronze Member Username: Jay4u-, - - Post Number: 42 Registered: Jul-06 | how about on cooolsat 7000; does it work |
Silver Member Username: The_devilPost Number: 154 Registered: Aug-07 | what channel is it????? |
New member Username: Koolboy2Post Number: 1 Registered: Feb-08 | Confirmed STAR ONE is working on VS ULTRA 61.5W..... |
Bronze Member Username: Taran420Post Number: 56 Registered: Jan-07 | Hey "a" where did you get the VID, AUD, and the PCR info from????????????????????? |
Bronze Member Username: 4azeefPost Number: 24 Registered: Aug-07 | do u know what name does it come under wen u scane it? thanx |
New member Username: Freedom_ritesMontreal, Qc Canada Post Number: 9 Registered: Jan-08 | azeef: it should be showing Ch-A |
Bronze Member Username: 4azeefPost Number: 25 Registered: Aug-07 | thanx man |
Bronze Member Username: MuchoPost Number: 91 Registered: Dec-07 | A very good question Taran. Since this info. is not posted anywhere, how did he come up with it? It could be the same person that came up with Star Plus or could it be Charlie, testing it before he will included to his package? |
Bronze Member Username: 4azeefPost Number: 26 Registered: Aug-07 | guys can u plz share insturction on getting on SV4000. thanx |
New member Username: Freedom_ritesMontreal, Qc Canada Post Number: 10 Registered: Jan-08 | azeef : if u do a blind scan u should be getting star plus , on the channel 601.. it's showing tv 601 |
Gold Member Username: NydasPost Number: 8746 Registered: Jun-06 | Star Plus is now a regular at TP 12324 (H) channel 601 Star One is available as stated earlier in this thread by anando, who started this thread with a very informative post. |
New member Username: ThischickPost Number: 2 Registered: Mar-08 | Star Plus has moved again and it's on tp 12323 on 61.5 Channel TV 716 Tested working since 1:40 pm today |
Bronze Member Username: 4azeefPost Number: 27 Registered: Aug-07 | i got StarOne working. it workded for few mins then it swhowing no audio vidio. anyone having same problem. is it gone already? |
Bronze Member Username: 4azeefPost Number: 28 Registered: Aug-07 | *Using VS Ultra |
New member Username: ThischickPost Number: 3 Registered: Mar-08 | Star One has moved It is now scanning into Pansat convert 2500/2700 as channel TV 718 on TP 12414 No need to set the VID, AUDIO, or PCD Just an AUTO scan of this TP will bring it in Enjoy! |
Bronze Member Username: Parmar37Post Number: 21 Registered: Oct-06 | not getting star one on 2700, tried scanning on 12414 still notting anyone else having the same problem. |
New member Username: ThischickPost Number: 6 Registered: Mar-08 | How many channels scanned in when you scanned TP 12414? Should be 15 channels and Star One is listed as TV 718 for now. |
Bronze Member Username: Parmar37Post Number: 22 Registered: Oct-06 | when i scanned it, i only got about 4 to 5 channels |
New member Username: ThischickPost Number: 7 Registered: Mar-08 | Are you sure you're pointed at 61.5? My scan brought in 15 channels not just 4 or 5. Maybe your reception is bad right now? Or your dish is not quite there? Not sure, but it's working right now on 12414 cause I'm watching it..... |
Bronze Member Username: Parmar37Post Number: 23 Registered: Oct-06 | pointed at 61.5, level 78 quility 99 scanned it again got 5 channels and 2 music channels, at 12414 |
Silver Member Username: Cricket674Post Number: 201 Registered: Feb-07 | people will there be any cricket matches on this channel |
Silver Member Username: The_devilPost Number: 155 Registered: Aug-07 | Yeahhhhhhhhhhhhhhhhhhhh Im getting both star one and star plus on Captiveworks600p |
Bronze Member Username: Taran420Post Number: 57 Registered: Jan-07 | only channel left to complete the package is star news |
Bronze Member Username: 4azeefPost Number: 30 Registered: Aug-07 | hey Jack, can u plz share a tp for both channels? thanx |
Bronze Member Username: Devang1987Post Number: 14 Registered: Oct-07 | Guys.....when you provide the TP for a certain channel (Star One/Star Plus) please include any REGULAR channels that are also on the same TP. Because for some people (including me).....the TPs provided here do not work......but other TPs in the proximity work. For example, my Star Plus did not scan on 12443 (original)....but I had to look up the TP of the 7772 channel and then scan on the same one.... So please Include some regular channels for both Star Plus and Star One |
New member Username: ChimpeOntario Canada Post Number: 2 Registered: Nov-07 | really jack? can u tell me ur TP settings? |
New member Username: JefflakePost Number: 1 Registered: Mar-08 | I got Star One and Star plus both on EchoStar 9 star one 10958 20000 H 3/4 v 6178 a 6179 p 6178 channel no. 718 Star plus 10958 20000 H 3/4 v 5922 A 5923 p 5922 channel no. 716( channel says Video Italia but its Star plus india) |
New member Username: ChimpeOntario Canada Post Number: 3 Registered: Nov-07 | ok i got both too on 61.5 Star PLus - Tp 12323 Hor 20000 and then scan Star One - TP 12414 HOR 20000 and then scan plus will come at 716 and star1 will come as 718..dunno for how long but it is working! enjoyy |
New member Username: ThischickPost Number: 8 Registered: Mar-08 | See what Mohit said? I posted that exact same info 3 hours ago I did find that Star One was also able to scan in on TP 12410 for those that can't get it working on TP 12414. Hope that helps Also, make sure it's 61.5 ECHO 3, don't know about others |
New member Username: Koolboy2Post Number: 2 Registered: Feb-08 | All i did is Auto Scan on my VS ULTRA and got both the Channel STAR PLUS Channel # 716 and STAR ONE Channel # 718.... |
Silver Member Username: Thakkar2000Post Number: 197 Registered: Jun-06 | hi guys..i get star one but not star plus ..i did a blind scan...i thin i aint getting the TP 12323 |
Bronze Member Username: Kishan2006Post Number: 17 Registered: Jul-06 | hey t23 it is not tp 12323 it is Tp 12326 and the channel number is 716 |
Silver Member Username: Vic123TorontoCanada Post Number: 127 Registered: Jul-06 | guys im getting star plus but not star 1:s please help when i edit 12414 n do all the setting d channels dont get scanned..??? |
Bronze Member Username: Kishan2006Post Number: 18 Registered: Jul-06 | go and scan TP 12326 and you all will get star plus |
Silver Member Username: Vic123TorontoCanada Post Number: 128 Registered: Jul-06 | nv got both the channels now good job guy keep up the good posts...cheers |
Bronze Member Username: JainivasPost Number: 13 Registered: Sep-07 | Getting both Star one(718) and plus(716) on Viewsat Extreme - Confirmed |
Bronze Member Username: PratikgrPost Number: 12 Registered: Dec-07 | guys greate improvements. what ab other star channels now. Spl sports. |
Silver Member Username: CoolgoosePost Number: 116 Registered: Jun-06 | Did anyone get it on 119 or 118.7 ? |
Bronze Member Username: EkoneunoPost Number: 25 Registered: Nov-06 | hi guys..i am getting star india plus on ch716 on viewsat ultra. but when i go to 718, it somehow reverts to ch 717. Can someone help me with a step by step of manual scanning on a particular frequency so that i can get star one too? thanks in advance |
Silver Member Username: RekmanMntl-Quebec-... Post Number: 327 Registered: Jun-06 | Hi there... Can someone Help me please... I have COOLS*T 5000 ... (1) PLEASE explain to me how you change the TP etcc.. so as to get STAR PLUS channel(indian)... PLEASE HELP ME TO SET MY RECEIVER PROPERLY.. My dish is pointed to ECHOSTAR 61.5 WEST.. (2) I HAVE LNB 118-119... bUT THEY ARE BOTH CATCHING ONLY INDIAN CHANNELS.. whereas one was suppose to catch INDIAN and the other was suppose to catch AMERICAN. please help.. |
Bronze Member Username: Koolkuttu87Post Number: 15 Registered: Dec-07 | i get it on my VS extreme by just scanning channels at TP:12414 on channels 716 and 718..thanks for the help and info guys |
Silver Member Username: Thakkar2000Post Number: 198 Registered: Jun-06 | hi kishan patel...yes i got it..i had it displayed as VINDI something like that |
Gold Member Username: Saqeeb9000Mughe dard rehta hai, ..., Mujhe bhook ... Post Number: 2681 Registered: Oct-07 | so now there are 2 channels any luck of finding those channel on 148 or 118.8 dish? |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 582 Registered: Jan-08 | MKM start a new thread and someone help you, sorry i dont know this box. |
Bronze Member Username: Sam_patelPost Number: 89 Registered: Jun-06 | MKM u have to just rescan 61.5 u will get both chennal 716 and 718 okay and now both chennal's are on dishnet and directv also and star news coming soon |
Silver Member Username: RekmanMntl-Quebec-... Post Number: 328 Registered: Jun-06 | NO pATEL... I JUST SCAN again but no 716-718 came... I always seen 717 .. but never 716-718.. I think there must be something else that must be done.. |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 583 Registered: Jan-08 | MKM if you have a blind scan, do it maybe that work |
Silver Member Username: RekmanMntl-Quebec-... Post Number: 329 Registered: Jun-06 | PLYMOUTH... hahahaha u see am still daNcing Rock N roll with my LNB 118-119... hahhahaha PATELLLLLLLLLLLLLLLLLLLL Thanks yaarr... I have done MANUALly all the TP one after another.. hahahaha... FINALLY i saw the 716 appear.. It was on TP 12.175 ...THANK you very very much my friend.. Biwi naach rahi hai yahan.. bahat khush hai.. becoz she would be able to watch KABHI saas bhi kabhi bahu thi... hahahahhaha BUT THE DN IS DOWN FOR THE TIME BEING ???... ITS SCRAMBLE CHANNEL .. |
Silver Member Username: LeafsPost Number: 520 Registered: Oct-07 | Satellite television broadcaster Dish Network Inc. will add five new Asian television channels to its lineup starting March 19. Through a deal with Hong Kong-based Star entertainment company, Englewood-based Dish (NASDAQ: DISH) will add Star India Plus and Star India One, plus three Mandarin-language channels: Star Chinese Channel, Star Chinese Movies and Channel V Taiwan, Dish Network announced Wednesday. The new stations add to existing South Asian and Chinese-language channels that the satellite network already offers. |
Gold Member Username: KirankumarKenya Post Number: 1969 Registered: Oct-07 | Donald Trump, Very good post thank you |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 586 Registered: Jan-08 | hey MKM i received now all Dn bev and Gc and other with my lnb invacom and i dance in the snow |
Silver Member Username: RekmanMntl-Quebec-... Post Number: 330 Registered: Jun-06 | YAHOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO........... I GOT THE STAR PLUS CHANNEL....... AM SO HAPPYYYYYYYYYYYYYYYYYYYYY.... now i have to work out hardly so as to catch AMERICAN CHANNELS.. OTHERWISE my kids wont give me peace...... PLEASE PLEASE.. EXPLAIN WAT TO DO .. AND HOW TO DO IT... WITH MY LNB 118.119....SO AS TO CATCH BOTH INDIAN & COMPLETE AMERICAN CHANNELS.... MY DISH IS TURN TO ECHOSTAR 61.5 WEST... satellite 119 echostar is giving GREEEN LEVEL -QUALITY.. BUT satelllite 118.8 DISH ANIK F3.. is RED WITH LOW LEVEL -QUALITY.... foufffffffffff.......... i repeated this 20 times... . NO ONE HAS BEEN ABLE TO HELP ME........ GRRRRRRRRRRRRRRRRRR |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 589 Registered: Jan-08 | do you have 2 dish 1 for 118- 119 and 1 for 61.5 |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 590 Registered: Jan-08 | Sorry you turn your dish do you change swew when you turn the dish |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 591 Registered: Jan-08 | do you change skew when you turn the dish |
Silver Member Username: VittuPost Number: 173 Registered: Oct-07 | ok I got StarPlus(11958H) and StarOne(11958H) on 118. Just scanned the channels on my FLU converted to Puff and the channel names also shows up as Star+ and Star1. Enjoy |
Silver Member Username: PlymouthQuebec city, Quebec Canada Post Number: 592 Registered: Jan-08 | For dish tuning Go to: Note dont go directly on your house ,i dont know why this think is free |
Bronze Member Username: WasimToronto, Ontario Canada Post Number: 35 Registered: Jun-06 | again im not expert in this satellite stuff. i have a viewsat ultra, can i get starplus and star one. the posts above are kinda confusing me. someone pls help me!?!?! |
Bronze Member Username: MuchoPost Number: 100 Registered: Dec-07 | YES JOHNNY BOY Bronze Member Username: Master_lee Post Number: 31 Registered: Oct-07 Posted on Saturday, March 08, 2008 - 05:34 am: -------------------------------------------------------------------------------- C/P Star Plus and Star One were uplinked but not yet made available to subscribers on channels 716 and 718 on tp 8 at 61.5° and tp 17 at 118° |
