Bronze Member Username: KrunchAre you living life or... Post Number: 14 Registered: Dec-07 | I see on dssworld a file to convert the FLU to a "puff". ??? Been out of the forum a while but can't for the life of me figger out what a puff is, and whether i should convert to it. Anyone?, and please don't giggle at me if it's obvious and I just can't figure it out. |
Bronze Member Username: SomokanoPost Number: 16 Registered: Nov-07 | Well I also just read on ftabins.net and I still don't know what is it I think we have to convert back to 2500 and load puff bin but I would rather wait and see if it is really good and working or not |
Gold Member Username: NydasPost Number: 8666 Registered: Jun-06 | It is an amateur's effort at creating a brand loyalty. He has taken the Pansat 2700 BIN, used all thE information that jvvh and Fwank7 have put out and created his own thing with its built in cuff branded clone killer. THERE IS ABSOLUTELY NO NEED FOR IT. |
Platinum Member Username: LklivesPost Number: 14195 Registered: Jan-06 | Charlie Nyda doesn't want anymore working bins with FTA.... |
Platinum Member Username: LklivesPost Number: 14214 Registered: Jan-06 | From FWANK7 to all: "First of all I have to thank Jvvh for always looking ahead of the game and for all he has done for us FLU/2500 reciever owner's.We all should be very happy and realize how lucky we are to have Jvvh on our side. The conversion bins we have now are running out of code space room.Jvvh has for a bit now has this new style of conversion bins he calls PUFF. With PUFF the BG (back ground) is put into the boot section freeing up the bytes that the BG takes up in the actual bin code itself.This new style also allows us to go a little bigger in bin size if needed to be. I believe it's from 448 kb to 512 kb maybe even a bit bigger then that maybe Jvvh will confirm the actual size we can go. With this New PUFF style bin you will need to convert back to 2500 using just the boot60 bin. As you have knight rider lights load the New PUFF 640 kb bin one time to get you converted to PUFF. This is the easiest way we have found to do it so far. Jvvh wanted something to show the peps when changing to PUFF that they will know that they have changed. So Ukronic came up with a new display on your reciever display screen that will show this. Once converted to PUFF your reciever display at start up will go from b 7 5, b 7 5 to P U F F , P U F F. Pause on F for 30 seconds then come ON. You can NOT load a normal b75 compressed 448 kb conversion bin to your reciever afterwards and it must be a new PUFF conversion 448 kb bin. You can NOT load a 448 kb PUFF conversion bin over the b75 conversion bins either, you must convert using PUFF 640 kb conversion bin first in order to load a New PUFF 448 kb conversion bin. For now who's ever PUFF 640 kb conversion bin you put on your reciever to convert to PUFF will be the BG you will have embedded into boot section of your reciever. Don't worry Jvvh says we need to come up with tools to allow you to change BG but that will be in do time. If you use my PUFF 640 kb conversion bin to convert to PUFF, Yes you can use other PUFF 448 kb conversion bins done by others afterwards but it must be PUFF style. NO you will NOT just have to use my PUFF 448 kb conversion bins. It will just keep my BG on your reciever thats all. Again the BG you will be able to change in do time. I have my PUFF 640 kb bin done already (Thanks to Ukronic) and it is a 253 bin so it is up and running. Just wanted to test it out first before I start releasing it to the public. :shock: Everyone will need to eventually change to the PUFF style bins but I will post both sets to give peps the time to convert over to PUFF but again you will have to eventually do it. Want to give HUGE THANKS to Jvvh for always looking out and passing his knowledge on to us. "You are truly the man Jvvh5897" Special THANKS to Ukronic for helping me understand and helping me out time and time again.If it wasn't for Ukronic as well, I wouldn't know most of the things I know now." |
Gold Member Username: NydasPost Number: 8711 Registered: Jun-06 | Only time will tell. |
Bronze Member Username: LotusbawaPost Number: 21 Registered: Oct-07 | I'm lossing my channels list everytime i load new JVVH bins. I have a convert FLU receiver. Will i be loosing my channels list when ever i load new PUFF bins also just like Jvvh bin. Is there a way that i don't loose my channels everytime i load new bin. |
Silver Member Username: Bill038Post Number: 528 Registered: Sep-06 | Try it Nalin, your a tester,,,,Right? |
Bronze Member Username: ChechiPost Number: 90 Registered: Apr-06 | lotus bawa are you ismaili? |
Gold Member Username: RtapFL Post Number: 1954 Registered: Jan-07 | good one bill. |
Gold Member Username: JuanchoDe los cerros mas alto..., BINDURABLE. Post Number: 2443 Registered: Dec-06 | I am using PUFF , I converted my FLU to PUFF, do as direct for the conversion, special loader, boot60 and bin jvvh 253 canam 253 PUFF are necesary, after that load the bin as usually you do it to converted to 2700a, BIN jvvh254 fortec-pansat254 canam .PUFF is working both provider dn/bev, STB is working a lot better now |
Gold Member Username: JuanchoDe los cerros mas alto..., BINDURABLE. Post Number: 2444 Registered: Dec-06 | very soon will be there a new jvvhXXX NKK PUFF, |
Bronze Member Username: ChechiPost Number: 91 Registered: Apr-06 | hey people leave Nalin alone, & get on with your lives. What about being kind and helpfull! |
Bronze Member Username: LotusbawaPost Number: 23 Registered: Oct-07 | Che G.: lotus bawa are you ismaili? No I'm not |
Bronze Member Username: Pdee333Post Number: 22 Registered: Nov-07 | I must admit, I am a bit of a PUFF myself.. But I've been really trying to be more macho.. eating red meat, watching hockey, spitting on the sideway etc. I hope it works out |
New member Username: Harry_longfellowPost Number: 2 Registered: Feb-08 | That's a poof not puff...... |
Bronze Member Username: KrunchAre you living life or... Post Number: 15 Registered: Dec-07 | Thank you very much LK for the concise clear answer. Makes perfect sense to me now. I am always a little anxious about booting in a new file type (mostly anxious about making sure i run the correct files in the future). But now I know it's a legitimate and intelligent update and won't hesitate to take the plunge. Thanks again! |
Gold Member Username: NydasPost Number: 8762 Registered: Jun-06 | PUFF is essentially a puff that LK uses a lot. She thinks it is good for her health. I have tried to encourage her to go to a psychiatrist for a long time. I hope she has or will. She has lately taken to fraud and scamming. This is serious and cannot be condoned. |
Gold Member Username: NydasPost Number: 8763 Registered: Jun-06 | Here is something for the backward Irish Immigrant LK now living in Key Largo Florida and for and for the Scotish ex-soldiers who know not how little they have become in this world. For African and the Indo-Pakistani crowd. http://www.youtube.com/watch?v=H6A91F2W7XM |
Silver Member Username: VittuPost Number: 176 Registered: Oct-07 | Coverted my FLU to puff and it's working great. Superfast channel change and fast key rollong...Is it just me?? heck I love testing. |
Gold Member Username: NydasPost Number: 8770 Registered: Jun-06 | The Gujaratis are taking over America. |
Platinum Member Username: LklivesPost Number: 14245 Registered: Jan-06 | no more 7-11's please! |
Gold Member Username: KirankumarKenya Post Number: 1971 Registered: Oct-07 | What is wrong with both of you guys relax guys life is too short |
Gold Member Username: JuanchoDe los cerros mas alto..., BINDURABLE. Post Number: 2460 Registered: Dec-06 | OK, there is other PUFF, the 254 lightning PUFF, they works the same .After I converted my flu to canam PUFF I am using now the lightning PUFF , It's the same any PUFF bin will works . very soon will saif release his PUFF, Very soon this will be the new sistem of bins for the converted to 2700a , IS easy no problem at all. |
Silver Member Username: DishloverToronto, Ontario Canad Post Number: 167 Registered: Jun-06 | Nalin can you post the kit for conversion to PUFF please? or let me know where to go to get it. Thanks |
Gold Member Username: NydasPost Number: 8823 Registered: Jun-06 | Make sure you do the PUFF Boot properly. [link removed] These are the 254 Puff BINs [link removed] [link removed] [link removed] |
Gold Member Username: NydasPost Number: 8826 Registered: Jun-06 | Tamara: I have not done the PUFF conversion, and am not able to answer too many question on the subject. Look at the threads in ftatalk.com. |
Silver Member Username: NewbiehaterFTAwhew what a stink Post Number: 211 Registered: Feb-08 | Nalin Nyda Gold Member Username: Nydas Post Number: 8666 Registered: Jun-06 Posted on Tuesday, March 04, 2008 - 06:50 pm: -------------------------------------------------------------------------------- It is an amateur's effort at creating a brand loyalty. He has taken the Pansat 2700 BIN, used all thE information that jvvh and Fwank7 have put out and created his own thing with its built in cuff branded clone killer. DO NOT CONVERT TO PUFF. THERE IS ABSOLUTELY NO NEED FOR IT. |
Platinum Member Username: LklivesPost Number: 14319 Registered: Jan-06 | Don't ya just love another bogus post filled with wrong info again by nalin.. |
Gold Member Username: NydasPost Number: 8850 Registered: Jun-06 | AKA RYERSON AKA RYERSON ARMY GROW UP!!!! |
Bronze Member Username: Spike52Post Number: 46 Registered: Aug-06 | Thanks for your clear and to the point answer LK. Explains alot. As usual LK hits the nail on the head. |
Platinum Member Username: LklivesPost Number: 14321 Registered: Jan-06 | YW.,.Jerry...nice to see ya again... Sox looking good in training, seen 3 games this week...and Celts are 1st to clinch plaoff spot....things are looking good.. |
Gold Member Username: NydasPost Number: 8862 Registered: Jun-06 | Jerry Conway: I am glad you have a deeper understanding and can understand the egomaniac LK. I have had a bit better understanding of psychological illness than you and you have yet to understand what egomania and megalomania is, particularly in relation to gross psychosis. |
Silver Member Username: NewbiehaterFTAwhew what a stink Post Number: 241 Registered: Feb-08 | Yeah, nalin that was your doctors diagnosis for you .Your the expert on that issue , no doubt. |
Gold Member Username: NydasPost Number: 8871 Registered: Jun-06 | Username: Newbiehater You are a totally maladjusted person sitting on the fringe of legality. You remind me of the 15-18 year olds who I was required to counsel when they were put in jail for minor offenses and then somehow got out after serving 1-2 weeks. |
Gold Member Username: Donnie1973Post Number: 2801 Registered: May-06 | I thought u were a retired dr?? Watch it Naughty... she will have u incarcerated. She knows the internet laws very well. U know u cant challenge her, that breaks every law in the civilized world... in her mind. |
Gold Member Username: Donnie1973Post Number: 2807 Registered: May-06 | things are starting to come together now... |
Gold Member Username: RtapFL Post Number: 1981 Registered: Jan-07 | to all newbies continue to listen to the nurse.hey wheres martini lmao |
Platinum Member Username: LklivesPost Number: 14322 Registered: Jan-06 | Nalin told me 2 different OTHER stories...thats she was a still working and world traveling 1...researcher 2....computer networking and software engineer... she got her lies are twisted, she can't remember them all..she does the same thing sometines when using these aliases too... seriously, she is either a DM mole, Ecoustics staff member, or a VERY ill person... |
Bronze Member Username: Spike52Post Number: 48 Registered: Aug-06 | Wont even waste my time LK on Nalins spin. LK by the way going to Celts tonight. TD BankNorth Later |
Gold Member Username: Donnie1973Post Number: 2811 Registered: May-06 | yeah. she said said something about an egineer before. nurse betty to me... or nurse ratchet |
Gold Member Username: RtapFL Post Number: 1995 Registered: Jan-07 | and now a tester. a tester who tells members no need to update to the puff system.what a waist of time with the old models.just get a new cw for 89 bucks and get rid of the headaches lol |
Gold Member Username: NydasPost Number: 8877 Registered: Jun-06 | Everybody has a different type of problem. Some have mjor problems - some minor. I sympathise with dantetn. He has to try and make the world and friend know that he is strong, although he is the female side of a Hmo relationship with RTAP. dantetn, most people in your situation feel compelled to prove their masculinity. I have seen 16 year olds getting into a fight to prove their masculinity. That was at a time when your type of orientation was not acceptable in society. But now everything is out in the open and you should not have to prove anything. It is people like Username: Newbiehater difficult ot evaluate. There's many a young person incarcerted for violent behaviour, when they have a manic psychosis needing treatment. Very hard to say which is which, except that about 25% of those youngsters jailed should be having psychiatric treatment. Unfortunately society 25 years ago chose to appoint social workers,nurses and other half trained persons to evaluate these people, till they discovered that they need a strong medical evaluation and treatment. In adult life, when there is no particular national emergency, there is a significant number of psychotics who volunteer for the armed forces to hide their violent behaviour or to find an outlet for their violent thoughts. People like LK end up in the army and even perform very well - they do because the more "enemy" they kill the more recognition they get. At least 5-6% of these very brave army type have manic psychosis and need psychiatric treatment. They miss action when they come home and get worse. |
Platinum Member Username: LklivesPost Number: 14323 Registered: Jan-06 | From FWANK7 to all: "First of all I have to thank Jvvh for always looking ahead of the game and for all he has done for us FLU/2500 reciever owner's.We all should be very happy and realize how lucky we are to have Jvvh on our side. The conversion bins we have now are running out of code space room.Jvvh has for a bit now has this new style of conversion bins he calls PUFF. With PUFF the BG (back ground) is put into the boot section freeing up the bytes that the BG takes up in the actual bin code itself.This new style also allows us to go a little bigger in bin size if needed to be. I believe it's from 448 kb to 512 kb maybe even a bit bigger then that maybe Jvvh will confirm the actual size we can go. With this New PUFF style bin you will need to convert back to 2500 using just the boot60 bin. As you have knight rider lights load the New PUFF 640 kb bin one time to get you converted to PUFF. This is the easiest way we have found to do it so far. Jvvh wanted something to show the peps when changing to PUFF that they will know that they have changed. So Ukronic came up with a new display on your reciever display screen that will show this. Once converted to PUFF your reciever display at start up will go from b 7 5, b 7 5 to P U F F , P U F F. Pause on F for 30 seconds then come ON. You can NOT load a normal b75 compressed 448 kb conversion bin to your reciever afterwards and it must be a new PUFF conversion 448 kb bin. You can NOT load a 448 kb PUFF conversion bin over the b75 conversion bins either, you must convert using PUFF 640 kb conversion bin first in order to load a New PUFF 448 kb conversion bin. For now who's ever PUFF 640 kb conversion bin you put on your reciever to convert to PUFF will be the BG you will have embedded into boot section of your reciever. Don't worry Jvvh says we need to come up with tools to allow you to change BG but that will be in do time. If you use my PUFF 640 kb conversion bin to convert to PUFF, Yes you can use other PUFF 448 kb conversion bins done by others afterwards but it must be PUFF style. NO you will NOT just have to use my PUFF 448 kb conversion bins. It will just keep my BG on your reciever thats all. Again the BG you will be able to change in do time. I have my PUFF 640 kb bin done already (Thanks to Ukronic) and it is a 253 bin so it is up and running. Just wanted to test it out first before I start releasing it to the public. :shock: Everyone will need to eventually change to the PUFF style bins but I will post both sets to give peps the time to convert over to PUFF but again you will have to eventually do it. Want to give HUGE THANKS to Jvvh for always looking out and passing his knowledge on to us. "You are truly the man Jvvh5897" Special THANKS to Ukronic for helping me understand and helping me out time and time again.If it wasn't for Ukronic as well, I wouldn't know most of the things I know now." :shock: Everyone will need to eventually change to the PUFF style bins but I will post both sets to give peps the time to convert over to PUFF but again you will have to eventually do it. |
Gold Member Username: NydasPost Number: 8887 Registered: Jun-06 | What the hack is LK doing in a Pancrap thread? She is lost. |
