Silver Member Username: StamantLA, FL USA Post Number: 388 Registered: Sep-04 | What could be the cause of a whine sound coming from my mids and highs which increases as the rpms increase? Could it be a bad ground or from the head unit? |
Gold Member Username: Dakangofkrunk16Boca Raton, Florida Post Number: 1277 Registered: May-07 | check ur RCA cables i had that happen sounded like a ghetto turbo lol |
Bronze Member Username: Bass_enjoyerPost Number: 21 Registered: Jun-07 | Are your mids/highs amplified? What type/brand of head unit do you have? I would check all grounds and any RCA cables used; don't run RCA cables near power wire. If the problem still exists I'm sure people on this forum will be able to help you. |
Silver Member Username: StamantLA, FL USA Post Number: 389 Registered: Sep-04 | Mids and highs are amplified. I have an older pioneer premier HU. |
Silver Member Username: Philly306New quote coming soon, North carolina Post Number: 954 Registered: Apr-07 | is your power wire for the amplifier running alongside the rcas? if so move it away from the power wire |
Bronze Member Username: Bass_enjoyerPost Number: 22 Registered: Jun-07 | Are your RCA cables near power wire? Are all of your amps grounded to the same point? Is this a problem that just started to happen? |
Silver Member Username: StamantLA, FL USA Post Number: 390 Registered: Sep-04 | Ya, kind of just started out of the blue. I have heard pioneer HUs are known for this problem. |
Bronze Member Username: Bass_enjoyerPost Number: 23 Registered: Jun-07 | Well here's a quote from Chad Lee about someone with a pioneer head unit with a similar problem (constant test tone/whine noise). "unfortunately that is a common problem with the pioneer headunits. not the indash, just the head units. anyways charlie, ground the rca cable to the chasis of your head unit. you can wrap a cable around one of the rca cable and the other end you can ground it to the chasis on the headunit. on the back of your hu, there is a little screw. just undo that and wrap the other end of the cable to that screw and screw it back on." |
Gold Member Username: Dakangofkrunk16Boca Raton, Florida Post Number: 1284 Registered: May-07 | i ahd the Pioneer DEH 780mp... i had that problem but it was just the RCA wires to close to Power wire... but another problem wit HU is recently it just stopped Workin outta no where... a very sad day for me |
Platinum Member Username: Chaunb3400All he does is catch t..., Alabama U.S. Post Number: 14031 Registered: Jul-05 | if it started all of a sudden sounds like a ground problem...never heard of an older pioneer having the shield ground problem |
Gold Member Username: FrkkevinResonant Engineering..., Fort Worth... Email Post Number: 4726 Registered: Nov-05 | alternator whine .. get some shielded RCAs amd double check the grounds my friend had a similar problem.. he had to upgrade plug wires because the signal was jumping from those |
Bronze Member Username: Bass_enjoyerPost Number: 24 Registered: Jun-07 | http://www.knukonceptz.com/productMaster.cfm?Category=RCA%20Interconnects I'd try the karma or krystal kables. I personally use the Karma kables and don't have any noticeable noise at the moment. Hope everything works out. |
