VSUltra help please...
Username: Deptrai_cachon
Post Number: 41
hi guys ,, my vs ultra keep freezing and some channels are autoroll .....
how can I fix this do i need new Bin or Keys .. ?
pleasse help me ! thanks
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 674
which bin you have
Post Number: 42
my current bin 03/05/08
if I need the keys... are those zeros or a letter O in the keys ???
Username: Nydas
Post Number: 8865
Ken: The nature of the current problems is part of the latest ECM. This time round, having exhausted the stronger methods of ECM, they went back to tweaking at the time of autoroll and in the key checking part. Most receivers are experinceing this problem.
The best you can do is turn autoroll of and turn autoTP off
Username: Plymouth
Post Number: 677
Nalin my Vs ultra work fine now
Ken go to menu keys and delete all provider Dn
made a hard reboot and load the last bin
and autoroll on on channel 200
reply if that work
Thanks
Username: Plymouth
Post Number: 678
Ken puts autoroll on and the keys come by itself
Before do a hardboot (backpanel switch off for 10 secs)
Username: Plymouth
Post Number: 679
Sorry bad post
Post Number: 43
so plymouth, i don't have to enter the key manulally ???
ok delete all dn key , hardboot, reload bin ...
ok let me try it then i'll let you know thanks for all your help guys ..i'm new to this so please be patient with me .. :-)
Username: Kirankumar
Kenya
Post Number: 2003
ken,
on vs ultra there is no need to enter keys manually,but as Nalin pointed out there are some strange things going on,so just be patient
Username: Drmunna
Post Number: 309
on my ultra there absolutely nothing going on, no freezing nothing.
u always do hard reboot after latest file installation, give receiver enough time to roll on and watch tv, as simple as that i dont know why u have to go and enter keys anyway.
put the new factory file if problems continues, install bin AND NEVER FORGET HARD REBOOT thats it.
Username: Plymouth
Post Number: 681
DrMumma thats ok on Bev or you have ultra 2
freeze just on Dn
