IS FLU Converted to 2700 working?
Username: Saaz
Post Number: 11
i uploaded the Jvvh_254.bin file day before yesterday and now since yesterday morning its not working.
is there any body comfirm me if the latest bin is working properly or not?
Thanks
Username: Nydas
Post Number: 8861
It is working.
1. Turn switch off at back and after 30 seconds turn it on.
2. Keep autoroll and closed captions off.
3. In Parental control menu, do a "set default keys". then Exit, exit and turn receiver off at the back.
4. Turn on and the keys will autoroll in about 3 minutes or less. That I can assure is better time than some of the more expensive receivers.
Username: Sadafmpd
Post Number: 18
Thanks Nalin, You are the best.
Username: Saaz
Post Number: 12
Thank Nalin, its working now.
i appriciate for your help.
Thanks Again
