Username: Kenroy Kingston,
Kingston
Jamaica
Post Number: 22 Registered: Jan-08
Friday, March 07, 2008 - 03:31 GMT i jus updated my cooltec. and every 5 mins scrambled signal comes up then in the next min it goes away.....can u heal me solve this problem?
Username: Saqeeb9000 Mughe dard rehta hai, ...,
Mujhe bhook ...
Post Number: 2726 Registered: Oct-07
Friday, March 07, 2008 - 03:32 GMT i think u put the youoriginal cools*at file.. make sure u put koolsat clone files..
Username: Kirankumar Kenya
Post Number: 1998 Registered: Oct-07
Friday, March 07, 2008 - 03:33 GMT sada, i think that question was not for you
Mujhe bhook ...
Post Number: 2727 Registered: Oct-07
Friday, March 07, 2008 - 03:35 GMT oops my bad....
Post Number: 1999 Registered: Oct-07
Friday, March 07, 2008 - 03:37 GMT if someone asks for a specific person for help,then we should respect them and keep out of it.lol
Kingston
Jamaica
Post Number: 23 Registered: Jan-08
Friday, March 07, 2008 - 03:38 GMT i didnt mean LK only.......anyone can answer
Username: Lklives Post Number: 14312 Registered: Jan-06
Friday, March 07, 2008 - 03:41 GMT Could be many things.. 1,,,start with doing a simple REBOOT, using rear swictch power OFF fro 2-3 minutes, then power back ON....see if that clears it up...a REBOOT is a simple fix for many problems...and should be done BEFORE and AFTER every new file upload.. 2...could have alot of memory corruption in the receiver, and need to flush it out by starting from scratch...factory reset/default...factory bin upload...new scans...recheck antenna settings...set date and time...upload latest fix...let latest keys autoroll...watch TV.. 3...could have some bad hardware ...cable/connections...loose dish....switch going bad ...LNB going bad...etc...but this is least likely..
Username: Lyndo Post Number: 2 Registered: Feb-08
Friday, March 07, 2008 - 03:43 GMT my c00lsat 5k does the same thing w/169 LBJ
Username: Lklives Post Number: 14313 Registered: Jan-06
Friday, March 07, 2008 - 03:44 GMT Anybody who can help should help...threads and posts should never be addressed to 1 person...there are many here who can help...this is all about exchanging and sharing info with everybody...
Username: Lklives Post Number: 14314 Registered: Jan-06
Friday, March 07, 2008 - 03:47 GMT Also this could be a bug in the coo*lsat bins, which the cooltec is modified from...but I would seriously look more towards the 3 choices above, I mentioned...
Mujhe bhook ...
Post Number: 2729 Registered: Oct-07
Friday, March 07, 2008 - 03:48 GMT ok thanks LK kenory first of all tell us which file did u downloaded?
Kingston
Jamaica
Post Number: 24 Registered: Jan-08
Friday, March 07, 2008 - 03:50 GMT Coolt*ec bin 169 03-03-08
Username: Lklives Post Number: 14316 Registered: Jan-06
Friday, March 07, 2008 - 03:55 GMT kenroy...do as I suggested..I'm sure your problem will be fixed...
Kingston
Jamaica
Post Number: 25 Registered: Jan-08
Friday, March 07, 2008 - 04:05 GMT well b4 i could do anything....a permanent scrambled channel came up....i guess ill be needing a new bin file?
Post Number: 2000 Registered: Oct-07
Friday, March 07, 2008 - 04:05 GMT Good post LK LK Platinum Member Username: Lklives Post Number: 14313 Registered: Jan-06 Posted on Thursday, March 06, 2008 - 10:44 pm: Anybody who can help should help...threads and posts should never be addressed to 1 person...there are many here who can help...this is all about exchanging and sharing info with everybody...
Mujhe bhook ...
Post Number: 2730 Registered: Oct-07
Friday, March 07, 2008 - 04:37 GMT yep kenroy cs sucks with supportwise.. throw the rec and buy something like viewsat,soniview or nfusion..neverbuy another cs..
Username: Lklives Post Number: 14318 Registered: Jan-06
Friday, March 07, 2008 - 04:51 GMT If U listened to me , the fix 169 will work..
Username: Nydas Post Number: 8858 Registered: Jun-06
Friday, March 07, 2008 - 07:16 GMT LK: TELL YOU CRONIES TO GET OFF THIS FORUM, AND YOU GO WITH THEM. THIS IS THE 10TH TIME YOU HAVE GONE AND COME BACK ONLY TO MAKE TROUBLE.
Username: Newbiehater FTAwhew what a stink
Post Number: 237 Registered: Feb-08
Friday, March 07, 2008 - 07:40 GMT Nalin you stupid pos . I have nothing to do with Lk or ryerson. You need help , proffesional help! Your paranonia is showing real bad bro.
