Bronze Member Username: Mississauga
Post Number: 83 Registered: Apr-06
Posted on I currently have four satellites - 91, 82, 148 and 119. Can I get 118.8 and 119 on the same LNB. If I can what should I do to get both satellites |
Gold Member Username: Kirankumar
Kenya
Post Number: 1981 Registered: Oct-07
Posted on you need a 30" or larger dish and change your lnb on 119 |
Silver Member Username: Madflea168
Post Number: 316 Registered: Jan-08
Posted on you will need a dual lnb 118/119 to replace the current 119 you have. |
