New member Username: Walter4125Post Number: 1 Registered: Mar-08 | Man!!! i was stupid enought to convert to "puff" now my receiver displays " P U F F" stays on "F" for a while and then starts displaing " P U F F" PLEASE HELP!!! |
Gold Member Username: NydasPost Number: 8729 Registered: Jun-06 | Do a revert to 2500 using the puff instructions and file for revert to 2500. Then reconvert to B75 Boot and use one of the B75 conversion BINs posted. The full kit is in full_kit254B.zip or later. Download and unzip in a new jvvh directory. Read the instructions in the Instructions.doc file. Also available separately in All__b75_254.zip file with all the conversion 254 BINs released so far using B75 boot. None of these are meant for PUFF BOOT. http://public.box.net/2500_full_kit |
New member Username: Walter4125Post Number: 2 Registered: Mar-08 | i'll try that Thank you man!!! |
New member Username: Walter4125Post Number: 3 Registered: Mar-08 | ok, when i try to download the "boot60" using the converter it reads "flash update fail"...am i doing the right thing? |
New member Username: Walter4125Post Number: 4 Registered: Mar-08 | enerytime i try to download any bin it "downloads" to 100% but it reads "write failed" and P U F F" comes back on! |
Gold Member Username: NydasPost Number: 8733 Registered: Jun-06 | When you are using "Revert to 2500" you should select to load "BOOT" and not "BIN" |
Silver Member Username: ShadycovePost Number: 162 Registered: Sep-06 | where could i find the puff stuff files? bin lookin but can't find....thanx |
New member Username: Freedom_ritesMontreal, Qc Canada Post Number: 7 Registered: Jan-08 | Remember only use the PUFF bin if you converted to PUFF using the JVVH_253_PUFF (640k) bin. Again you will have to switch eventually. Use the (b75) one if you haven't converted to PUFF yet. If your reciver doesnt show PUFF DO NOT USE THIS BIN use the one I have already posted for converted B75 in this section. Jvvh_254_Nkk.bin ---------------- The "regular way" bin. Jvvh_254_Nkk_PUFF.bin ---------- The "PUFF way" bin. You can not use a "PUFF" bin in a "regular" converted box. A regular converted box will show "b-75" on the display when turned ON You can not use a "regular" bin in a "PUFF" converted box. A PUFF converted box will show "PUFF" on the display when turned ON puff files: b-75 files: |
New member Username: Melissa666Post Number: 8 Registered: May-06 | Same thing for me - after loading all the PUFF files, (as per the instructions), it strated displaing only P U F F, P u F F, ... and nothing else. I tried to converted it back (again as per the instructions) and now I am getting message - ACCESS DENIED Can't open serial port. Please help ... |
Gold Member Username: NydasPost Number: 9039 Registered: Jun-06 | As a suggestion, if you can't revert to 2500, you could try and force CS_253T_PUFF_BOOT_Serial_Lightning.bin (640K) and then add the 254 PUFF 460K BIN of your choice. |
New member Username: Melissa666Post Number: 9 Registered: May-06 | For the "Access Denied", it was my mistake. But now, when I am trying to load B60 - failed!, X_BL95.... - failed. And the only thing that keep displaing is P U f f, .... |
Gold Member Username: JuanchoDe los cerros mas alto..., BINDURABLE. Post Number: 2522 Registered: Dec-06 | That is very simple , when the first P appear load bin 254 Nkk PUFF using loader bl 1.40 setup default keys and wait for A/R. here is the link for the file[link removed] |
New member Username: Melissa666Post Number: 10 Registered: May-06 | Thanks Nalin, I tried! After downloading the CS?253..._BOOT_Serial_L.bin, the message was WRITE FAILED, (ER2). Isn't there a general reset, and to start all over again? |
Bronze Member Username: Melissa666Post Number: 11 Registered: May-06 | Thanks!!! To both of you. You are the best!!! The 254 Nkk works! |
Gold Member Username: NydasPost Number: 9049 Registered: Jun-06 | Mellisa: Good experience. There has been a problem with jvvh_PUFF_254 and version v2 is out now. Nkk makes good conversions. |
Gold Member Username: JuanchoDe los cerros mas alto..., BINDURABLE. Post Number: 2523 Registered: Dec-06 | The bin 254 Nkk PUFF makes everything simple, it works on all clones of pansat2500a converted receivers to PUFF . no more IR's problems. |
