Can I get 118.8
Username: Mississauga
Post Number: 83
I currently have four satellites - 91, 82, 148 and 119.
Can I get 118.8 and 119 on the same LNB. If I can what should I do to get both satellites
Username: Kirankumar
Kenya
Post Number: 1981
you need a 30" or larger dish and change your lnb on 119
Username: Madflea168
Post Number: 316
you will need a dual lnb 118/119 to replace the current 119 you have.
