No Channels
Username: L1l1l1
Post Number: 18
I have a viewsat xtreeme, I had to do a factory default, then I loaded the new factory bin, and then the latest bin. I have been trying to add the channels through blind scan or auto scan, but when I do a blind scan, it never asks me if I want to save the changes, so no channels get loaded.
And when I do an auto scan, it asks if I want to change, but there are no channels to be saved, so I still have no channels.
My dishes are at 119.0 and 61.5.
Can someone tell me how to add the channels.
Thanks
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 618
That's because no new channel scan, if found new channel it ask for saved.
Delete sat in channel scan and rescan it
Username: L1l1l1
Post Number: 19
Do I need to setup the antenna settings since it is at factory default, or is that already done.
Should I do a blind scan again?
Username: Plymouth
Post Number: 622
Yes you need to set, if no good.
Do a blind scan because freq tp change often.
Username: Kirankumar
Kenya
Post Number: 1974
Jill,
can you post your antenna settings so we can take a look at it
Username: L1l1l1
Post Number: 20
This is my antenna setting
Satellite > Echostar 3 61.5 and Echostar 7 119
LNB Power = ON
LNB Type = Standard
LNB Freq = 11250
22KHz = Off
TP Freq = 12326 - 12224
DiseqC = None
Motor = Off
Legacy SW = None
Kenya
Post Number: 1976
Jill,
change your Diseqc settings,
for 119 port 1 and for 61.5 port 2
please post results
Username: Tapeman
New York City in-HD, NY
Post Number: 2538
That if she is using a DISEqC switch
She could have an SW21
Well
to me yo sound like yo got a combination of 2 or 3 different issues but very simple
Even if she has none on D-sw she still can get a scan
- First Identify what type of a sat combiner are yo using?
- Second which bin did yo load?
- Yo can't use tp 12224 on 61.5 anymore use 12326
In Antenna setup
If yo are using sw21 then enable legacy sw21 on
If using D-Sw then assign each sat to proper matching port
Kenya
Post Number: 1978
King,
she is using 12326,but i should have asked her about switch type,thanks for helping out
Username: Tapeman
Post Number: 2539
No problem at all
If she was using 12326 and none on D-sw she would of got a scan from the default (default is always port-1)
This is why I know she got a combination of 3 simple issues
Username: Lklives
Post Number: 14266
Reinput the correct antenna settings ....corresponding to your hardware configuration with the sats, LNB's, cables, switch type, and switch ports..
The receiver has no clue what u have or did on the roof, thats why U need to tell it, with correct receiver antenna/dish settings..and there is NO standard settings and NO "1 shoe fits all"..U gotta go look on the roof and see whats up there and how its all configured...thats why U ALWAYS WRITE THEM DOWN AND SAVE THEM...unless U like climbing..FTA 101
Username: L1l1l1
Post Number: 21
I changed the port setting, I auto scanned 119, and I got the channels on the list, but I don't have any picture or sound, it says searching signal. I have the latest bins loaded.
What do I do now?
Username: Lklives
Post Number: 14270
U may have a dish out of alignment or bad cable, or connection...or bad antenna/dish settings
U may need to just wait a few minutes while the DN keys change now...or manually input them with AR off...U may need to do a simple rear switch reboot...
and if none of this is making sense, then U need to hit the manuals and do some basic reading..
U need to provide alot more info...beginning with if this ever worked for ya..
Kenya
Post Number: 1980
Jill,
just wait for about 10 minutes for keys to autoroll
Username: Tapeman
Post Number: 2541
Is your auto roll on
Yo loaded the latest bin that's what yo said
But my question to yo is:
- What is the bin yo loaded?
- What type of Sat combiner do yo have?
Username: L1l1l1
Post Number: 22
African, you were right, it came up after 10 minutes.
Kenya
Post Number: 1982
Jill,
glad it worked out for you.
please write down your settings some where for future use
enjoy
Kenya
Post Number: 1983
Jill,
enjoy
