For missing channels and Tps on echostar
Username: Doreenakadj
Ontario Canada
Post Number: 1277
I noticed a few weeks back that I have to scan echo1.2 and then echo 6/8 or 8/10 depending on your receiver to get ALL echostar channels and TPS. also make sure the disqe is set for your system properly and you may have to use the arrow key for TP setting to come in right.
Maybe this doesn't work for other receivers but it works for CW 600P. Just thought I would share this with you all. I know it sounds strange but echo 1.2 is showing up as ehco 6.8 and a lot of the sats are not showing up right at all EG: nimiq 1 is showing as echo 6.8 etc... Its the TP and disqe setting that you have to change in oder for you to get them all. Move the arrow keys till you get the best signal for TPs and change the NONE on your disqe settings to what ever your set up is set for .... mine is 1 for echostar 6.8 use the same settings for echo 1.2 and you get ALL echo TPs and Channels
Like I said this works for me
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 619
Doreen i try this on my viesat ultra but the higher signal not good for me. If i made this i lost channel. Who have the present list for sat scan freq tp.
Give me please
Thanks all
Username: Metallica
Post Number: 244
Hey Doreen don't tell me that you type all of that..how come i don't see any TYPO..
Ontario Canada
Post Number: 1280
PST... whispering>>>>>> i used spell check HEHE
Ontario Canada
Post Number: 1281
Plymouth .. The TP's are V and H.. some don't have channels in on either meaning NO channel for the freq. setting. To locate all the TP's ... I don't have that info right now but will look into it
Ontario Canada
Post Number: 1282
http://www.dishchannelchart.com./ great site for all channels and tp settings
Username: Lklives
Post Number: 14264
Actually for sat and TP frequencies listings and info, use lyngsat.c*om...DN and Bev circular polarity at www.lyngsat.com, the TP's are listed as R-L...and are V-H for all linear LNB polarity and satellites..
The only way to get ALL echostar channels is to have LNB's aimed at each echostar satellite, and keep your TP's up to date and scanned.......DN will commonly simply change channels to other Echostar sats and to other TP frequencies...
Username: Plymouth
Post Number: 623
I went list for sat setup, like Tp freq and lnb high/low too, Lk i know Lingsat but i dont see this. One guy post it and i dont found.
Thanks all
Username: Lklives
Post Number: 14269
All U need is the satellite, TP and its frequency, and polarity info...keep it simple..
Username: Plymouth
Post Number: 625
Sorry i'm comeback. LK That what i need please and i save for futur
Thanks
Ontario Canada
Post Number: 1287
http://www.lyng/sat.com/packages/dish110.html
just romove the "/" in lying/sat
Ontario Canada
Post Number: 1288
remove i meant .. darn typos again OOPS SEES my bad silly me
