Bronze Member Username: 23marsblackmon23
Post Number: 13 Registered: Aug-07
Posted on The question is that I'm looking for a pretty decent system. I was wondering which set up would have more spl. 2-10" kicker L5 ran on a 1000.1 kicker amp or 1-JL 12w7 ran on 1000 watt JL amp Both systems are going to cost about 1,000 bucks. So give me any info on what you know |
Silver Member Username: Drant19
DUB-C,
TX
Post Number: 444 Registered: Aug-07
Posted on 12w7 w/HO box = spluge in your pants good |
Silver Member Username: Bonhamd
Northern,
Michigan
Post Number: 500 Registered: Nov-07
Posted on i think you can get the Kicker setup for much cheaper than the JL setup. I personally would go with the JL setup |
Gold Member Username: Nd4spd18
Northwest PA
Post Number: 6720 Registered: Jul-06
Posted on JL, especially if you re going to use an HO box. No question about it. |
