For channel StarOne I am editing as you posted before for panset Flu 2500 converted to 2700. After changing setup below and scaning Star One is not coming up. Please tell me what i an doing wrong. ON PANSAT 2700, PANSAT 2700 CLONES AND PANSAT 2500/flu CONVERTED. Menu/Dish Setup/Advanced scan Select Echo 3 at 61.5 In TP menu, right arrow till 12443 H
Down arrow to Video. Change Auto to 5666 Down arrow to Audio. Change Auto to 5667 Down arrow to PCR PID. Change Auto to 5666
Now there are two. Star Plus is currently a regular channel on Echo 3 (61.5W) at TP 12324 or 12323 H - Channel 601. It was there yesterday but it seems to have disappeared. The other channel is Star One, which was in experimental stage yesterday on TP 12414 H, with Video -4898, Audio 4899, and PCR 4898 settings. As of now both these seem to have disappeared from the converted receiver I just tested on. somebody else might be able to answer you as to what has happened, as I am unable to do any testing and tweaking for the next 8 hours or so.
Star Plus is now Ch 716 on Echo 3 (61.5W) TP 12329 H SR 20,000 If you don't have this TP, add it and then do a TP scan leaving the other parameters on Auto. Star One is said to be at 12416, but I have not found it yet.
