Another clipping question
Username: Diehlerman
Post Number: 20
I have 2 12" CVR's but I'm only using 1 in a ported box due to limited space. kicker recommends giving it 300w RMS so if I were to get the kicker zx 300.1, which puts out 300w RMS, I wouldn't push the amp into clipping as long as the gain is set correctly?
Username: Somedonniedude
Illinois United States
Post Number: 1115
It will be fine, but I would get the zx400.1 if you have a dual 4 ohm, since the sub can handle more than 300w.
Post Number: 21
ok. awesome, that's what I was thinking about doing. just didn't want to fck anything up.
Username: Th3pwn3r
Post Number:...
Post Number: 7224
As long as you adjust your gain properly you won't drive the amplifier into clipping.
