Bin for converted 2500/2700a
Username: Freedom_rites
Montreal, Qc Canada
ftatalk*com
Montreal, Qc Canada
Attached is the Jvvh_254_Nkk bin for the Pansat 2500 & clones.
DN Tested....
If you are having reboot problems turn A/R to OFF
www.savefile*com/files/1420076
Username: Leafs
Post Number: 519
new pansat convert file is posted at www.ftasolutions.co.nr
Username: Lucia
Calgary, AB
Post Number: 580
works great thanks
Username: Slicee
Bflo, New york Usa
Post Number: 36
waiting for picture after loading this bin ,,,,why ?
Username: Lucia
Calgary, AB
Post Number: 582
slice olife, the person who converted (Nikk) said in a post that if thats happening go to channel 200 and wait for keys to roll sometimes it gets to 400%
that didnt happen to me so i dont know if that works.
Username: Chichos26
Post Number: 99
works great to me thanks
Username: Nikk
Post Number: 1611
It does the "wait for picture" after loading because keys changed in the middle time since the BL bins were out and this bin was created...
Username: Nydas
Post Number: 8731
For Pansat 2500/FLU new conversions and converted to 2700
Use only on unconverted 2500/FLU or converted receivers.
DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones
Everything you need for 2500/Flu to 2700 conversion in one package.
Instructions included.
The latest files jvvh_254_Nkk.bin and jvvh_254.bin and other conversion bins.
Some jtag files are also included.
The full kit is in full_kit254B.zip or later. Download and unzip in a new jvvh directory.
Read the instructions in the Instructions.doc file.
Also available separately in All__b75_254.zip file with all the conversion 254 BINs released so far using B75 boot. None of these are meant for PUFF BOOT.
http://public.box.net/2500_full_kit
Username: Jwl1
Post Number: 235
It's been reported that the new JVVH_254_NKK is having little bits of freezing, but only for a few seconds at a time.
Username: Jwl1
Post Number: 236
Hi Nalin! You sure are up late. Nice to see you.
Username: Nydas
Post Number: 8734
I had to test the new BINs before going to bed.
Tested both the jvvh_254.bin and the jvvh_254_Nkk.bin and both are working great on DN.
Username: Sarahk
Thunder Bay, Ontario Canada
Post Number: 39
can we use either for pansat 2700/a?
Username: Metallica
Post Number: 235
No you CAN NOT..the jvvh bin is for the Pansat 2500/FLU converted to 2700..
and the original Pansat 2700 are using this bin..
03-04-08 TBL 254 Bin
http://www.ftabins.net/forumdisplay.php?f=129
Username: Espn3
Post Number: 254
Nalin, what's the difference between jvvh_254.bin, jvvh_254_Nkk.bin and
jvvh_Fortec-Pansat_CanAm_254_(b75).bin ?
Which is the one for the FLU converted to Pansat 2700 ? thanks.
Montreal, Qc Canada
JOHN JOHSON : YOU CAN USE THE ONE YOU LIKE, BECAUS THEY ARE ALL CLONE SAFE SO THEY WON'T KILL UR RECIVER, I SUGGEST YOU TO USE JVVH_FORTEC_PANSAT_CANAM_254_9B75).BIN
Username: Bluegillbill
Post Number: 37
Both viewsat&pansat has freezing problems
Username: Espn3
Post Number: 256
Jami, thanks. Waiting for an answer I loaded jvvh_254.bin and no problems so far.
blugillbill, no freezing on my FLU converted to Pansat 2700 and using jvvh_254.bin
I have also a viewsat ultra clone ( ebox ) and no freezing problems on that using
PFTAUSW-080305U.PGM
Username: Nydas
Post Number: 8737
john johnson: One is a generic one, probably by fwank7 (the current hotshot working closely with jvvh), the other is by a guy called Nick - shortened to Nkk.
The details of how to convert are public. Anybody can use that info to create his/her own version. Hence there are versions by Lothario, Saif, and a couple of others.
There is new trend also. UKR was one of the first to collaborate with jvvh. They have created a new boot, to accomodate more memory. It is called PUFF. PUFF Boot requires to be installed first and then only PUFF BINs will work with it. I have not tried this yet, so I do not know if it is good. Theoretically it sounds OK.
Username: Bangle
Post Number: 33
can someone point me to CS_Lightning_254 convertion file ? I like that lightning version.
Montreal, Qc Canada
Post Number: 15
unfortunatly didnt see lightning bins for a long time
Username: Nydas
Post Number: 8741
I don't see a CS_254T_lightning or the BL_254T_lightning yet. for all the latest conversion BINs, go to
[link removed] or get from
http://public.box.net/2500_full_kit (full kit)
or the 254 b75 files in All_b75_254.zip
Username: Nydas
Post Number: 8754
The conversion CS BIN is only released in the PUFF version. It is avaiLAble at
[link removed]
YOU MUST FIRST INSTALL PUFF BOOT BEFORE INSTALLING THIS. YOU DO IT AT YOUR RISK.
