FLU / 2500 to PUFF Conversion - by AV
Username: Asharfi
Post Number: 1884
Hello,
I've successfully converted my two little Fortec STAR Lifetime Ultra receivers to PUFF and they are working good. I am posting the PUFF Conversion kit that has all the instructions and files you need to convert your FLU OR Pansat 2500 to PUFF. All the instructions are by me and they're very easy to understand. Please read the instructions at least 3 times before you start the conversion.
A lot of people are asking what is PUFF? Well, PUFF is basically a simple name that JVVH gave to his new conversion. We all know that the converted FLU/2500 - 2700 receivers use original Pansat 2700 bins that are modififed and compressed. But, those bins are now becoming very heavy in bytes and that's why JVVH came out with his new method that will reduce the bin's size. Anyway, this is kinda complicated to explain, so leave this aside and use the conversion kit to convert your FLU OR Pansat 2500 to PUFF. This kit is both for the converted FLU/2500 AND the unconverted FLU/2500 receivers. Have fun and please post your comments here. Enjoy!
PUFF Conversion Kit : Click here to download
Username: Foxcroft
Post Number: 8
Does not work for me, please fix your file.
Thanks
Username: Vittu
Post Number: 172
what file? I downloaded the file with no issue. Haven't loaded it yet if this is what you are talking about..
Username: Foxcroft
Post Number: 9
Try to unzip any of them
