I wanna make sure I have everything right
Username: Ducka
Shelby Township, MI United States
Post Number: 98
Okay so I go home on friday and plan on doing alot of work on my system and I want to make sure I have everything right before I go spending money.
I plan on buying 0 gauge wiring notsure exactly how much but from there I will put on a fused distribution block that will split of to 2 strands of 8 gauge(would use 4 but I already have some 8 let me know if I should use 4). I plan on using less than 5 ft of 8 gauge wire from the distribution block running to 2 crunch amps(the amps are supposedly 500rms. anyway I already have one and it seems reliable so I think I will pick up another). Each amp will be connected to 1 alpine type r subwoofer setup to be 4ohms. Also I plan on running a short amount of rca cable from the lead amp to the other one.
I think that covers everything. Let me know if you see any problems with what I plan on doing so I can correct it before I go buying sh1t.
Thanks
Username: Ducka
Post Number: 104
bump
Username: Kingandsons07
Lincoln, Nebraska U.S.A
Post Number: 841
GOLD
Username: Ducka
Post Number: 107
since Quentin's post was 100% useless(ftl)...
bump
Username: Rovin
4 10 Pioneer...
Post Number: 13282
make sure u got ring terminals \ rem wire & rcas ....
Username: Stateprop486
PA
Post Number: 953
get the kicker PKD1 1/0 wiring off ebay...thats a great kit...comes with 2 distribution blocks, but u will need to buy seperate RCAS cuz they dont provide it. go to knukonceptz to get there twisted pair of rca.
http://www.knukonceptz.com/
http://cgi.ebay.com/New-KICKER-PKD1-Amp-Kit-1-0-Gauge-AWG-Dual-Wire-05PKD1_W0QQi temZ170199061205QQcmdZViewItem?hash=item170199061205
Username: Ducka
Post Number: 112
Okay but beside that Im good to go?
thanks alot guys
Username: Ducka
Post Number: 116
It probably going to be running <1000watts(rms)
Would I need a new alternator? Im pretty sure mine is stock I'll have to check.
PA
Post Number: 959
1000 watts is fine on a stock alt cuz im runnin a zx1000.1 on my stock 80amp alt.
Username: Ducka
Post Number: 117
okay I believe my alt is like 102 or 105 amp so yeah im good there then. Thanks state.
Anything else that you guys can think of let me know.
Username: Ducka
Post Number: 126
Over summer I plan on building my own boxes for 2 12" type-r's. Does anyone see a problem with facing one into the car and the other facing the opposite way into the trunk(toward the hatch)?
car is an olds alero and boxes will be slotted
Username: Ducka
Post Number: 130
buuumpppp
Username: Ducka
Post Number: 149
Does anyone know a good price to pay for 12" alpine type -r's?
from what I can see $130 a piece seems to be a good price.
Username: Ducka
Post Number: 154
bump
Username: Snarl2004
Digital Design 9515, Massive Audi...
Post Number: 2220
130 seems good
as for the box ive got no clue sry
Username: Ducka
Post Number: 155
alright thanks
