How do I get 61.5?
Username: Meyerlansky
NYCUSA
Post Number: 8
Hi Guys and Girl. :-)
I plan to buy a dish from ebay and use it to try and get 61.5 for the Desi channels but I have no idea how to point and angle the dish correctly. What do I need for this job? I cant rememeber the name of the little device the "installers" use. Are there any other ways to do this? Thanks!
BTW, I am using cs5000 on Dn if that matters.
Username: Bandizzy
Post Number: 213
http://www.dishpointer.com/
Username: Bandizzy
Post Number: 214
You can use your c**lsat for a meter and lyngsat*com for a good transponder.
NYCUSA
Post Number: 9
Much Obliged Shlitz!
Username: Saqeeb9000
Mughe dard rehta hai, ..., Mujhe bhook ...
Post Number: 2676
dracu you need a satfinder (its like a compass).. it will tell u sat direction..
search on google/ebay..
NYCUSA
Post Number: 11
Bahut shukriya Sada-ji. Ham Google karengeN. :-)
Username: Kirankumar
Kenya
Post Number: 1964
if you are buying a dish,make sure it is 30" or larger.that way you can have 119,110 and 118.7 all on one dish.by the way 118.7 will give you international channels.
you need 2 lnbs
Username: Rtap
FL
Post Number: 1948
this is what you need
NYCUSA
Post Number: 13
Hey thanks so much guys, this is excellent info!
I love this hobby!
