Stuck in do not power off stage
Username: Soprano
Post Number: 9
what can i do (shut it off or what)
Username: Kirankumar
Kenya
Post Number: 1945
what are you talking about.
give details of receiver
Username: Dimwitt
Post Number: 445
you will have to turn it off , then you will get ---- on display . load the factory bin with the null cables to get rid of ---- , then latest bin.
Kenya
Post Number: 1947
switch off
download factory bin 132 with cable if you have one
then load the file 122607.but you will get a lot of freezing
Username: Soprano
Post Number: 10
viewsat ultra ,using a null cable can't get program to upload
Username: Dharm_ram
Post Number: 128
frank....is this ur problem?
Username: Soprano
Post Number: 11
yes i tried to down load an old file this morning and stuck in dono't power off stage ,now trying to load factory file can't get file to take on loader 2 file 132
Username: Dimwitt
Post Number: 446
Click "PC --> STB", then turn the power switch to "ON"
Username: Soprano
Post Number: 12
still getting nothing but the four dashes
Username: Dharm_ram
Post Number: 129
frank you may have to try again couple of times....try switching off the STB and then turning it on again while it is connected with your computer. also try using loader software from viewsat on their website
Username: Soprano
Post Number: 13
back in the sunshine thanks for the help
