my pansat 2700a is working fine but when i watch a channel for a while it will freez and it will say waiting for picture start doing percent and come back on this is annoying can anyone help me
if you installed the puff bin you would be jtaggin it now so your ok.did you do a hard reboot after loading the newest fix.a hard reboot is simple just turn of rear switch on stb wait 2 to 4 minutes then turn on.this procedure helps out in freezing issues.if problem continues just load the factory bin then load the newest bin.
