Bin 254
Username: Charjam
Post Number: 326
Is anyone having trouble opening bin 254 . I have downloaded it from crazy 4-5 times and dsstester once and i cannot open them . Now i can go to another file that i have on my com. and open it . i have laptop with Vista any help out there on this i have a pansat 2700
Username: Charjam
Post Number: 327
Look fellas i am not drunk and i don't drink but like i said i downloade this file from crazy 4-5 timesput it on a cd that is what i been using then i downloade it to my desktop i still could not open it then i downloade it to my doc., and opened it and now i am up and running
Username: Ohbeeman
Post Number: 12
I downloaded from Future-FTA works OK
Username: Dishlover
Toronto, Ontario Canad
Post Number: 166
I downloaded from Nalin's post in this forum and working fine
Username: Halo
Toronto, Ontario Canada
Post Number: 408
Download from www.dishkeys.tk it works fine
Username: Freedom_rites
Montreal, Qc Canada
Post Number: 12
Remember only use the PUFF bin if you converted to PUFF using the JVVH_253_PUFF (640k) bin.
Again you will have to switch eventually.
Use the (b75) one if you haven't converted to PUFF yet.
If your reciver doesnt show PUFF DO NOT USE THIS BIN use the one I have already posted for converted B75 in this section.
Jvvh_254_Nkk.bin ---------------- The "regular way" bin.
Jvvh_254_Nkk_PUFF.bin ---------- The "PUFF way" bin.
You can not use a "PUFF" bin in a "regular" converted box.
A regular converted box will show "b-75" on the display when turned ON
You can not use a "regular" bin in a "PUFF" converted box.
A PUFF converted box will show "PUFF" on the display when turned ON
puff files:
http://www.savefile.com/files/1420233
b-75 files:
www.savefile.com/files/1420203
Username: Nydas
Post Number: 8744
Please make sure you all understand what BIN 254 means to different people.
Genuine Pansat 2700A/E owners - they use
x-87bl_080304_b75_254_api.bin
Clone Pansat 2700 users use
Pansat-C 2700 254v1 TiVo.bin
2500/FLU converted to 2700, use
jvvh_254, jvvh_254_NKK Saif, Lothario, CS_254T_lightning, BL_254T_lightning, and several others. To complicate thing, this last group has been offerred the PUFF Boot and PUFF BINS to correct space related problems.
Make sure you use the right BIN with the right receiver.
Username: South2
Post Number: 68
hi Nalin,
I read that eventually we'll have to convert to PUFF. Can you guide me to conversion kit (from B75 to PUFF). Would you suggest converting to PUFF now or later? Thanks.
Username: Jwl1
Post Number: 238
Personally, I would say later, after there has been more testing done on it.
Username: Nydas
Post Number: 8747
The B75_254 is working fine. Just had a key change on 0101 and it took about 3 minutes to autoroll.
I think this particular ECM might be one of the old trick of the providers and you can less freeze ups with autoroll off. Autoroll will work whether or not you have kept it on but freeze ups might diminish if autoroll is off.
