It will be released ata least 2 hours after the genuine 2700 BIN is released. If you have a converted receiver, you should always know the simple fact that the conversion BINs are derived from the original Pansat BINs by BL.
-Use only on unconverted 2500/FLU or converted receivers. -DO NOT USE ON Genuine Pansat 2700 or on Pansat 2700 clones -Attached is the Jvvh_254_Nkk bin for the Pansat 2500 & clones.
-If you are having reboot problems turn A/R to OFF -DN Tested....
john johnson: One is a generic one, probably by fwank7 (the current hotshot working closely with jvvh), the other is by a guy called Nick - shortened to Nkk. The details of how to convert are public. Anybody can use that info to create his/her own version. Hence there are versions by Lothario, Saif, and a couple of others.
