Username: Decryptor Post Number: 38 Registered: Jun-06
Monday, March 03, 2008 - 22:46 GMT when I perform a blind scan on Echostart 7 and 6,8 I got lots of duplicate channels. Is there a way to get rid or at least minimize the duplicate channels beside editing the channel list manually? thanks.
Username: Saqeeb9000 Mughe dard rehta hai, ...,
Mujhe bhook ...
Post Number: 2623 Registered: Oct-07
Monday, March 03, 2008 - 22:48 GMT menu, delete satchannel, then do a blind scan
Username: Decryptor Post Number: 39 Registered: Jun-06
Monday, March 03, 2008 - 22:57 GMT did that. even did a system default. some channels are broadcast on both Satellites 110 and 119.
Username: Plymouth Quebec city,
Quebec
Post Number: 534 Registered: Jan-08
Monday, March 03, 2008 - 23:42 GMT Maybe try a auto scan Sada because several channel presently double
Username: Madflea168 Post Number: 303 Registered: Jan-08
Tuesday, March 04, 2008 - 08:00 GMT make sure to get the right settings to lock on 110 and 119, then just do auto channels scan, should be alright
Username: Jayson Post Number: 192 Registered: Aug-06
Tuesday, March 04, 2008 - 12:09 GMT scan one sat at a time and make sure to turn off the satellite you are not scanning.......
Username: Luser Post Number: 92 Registered: Nov-07
Wednesday, March 05, 2008 - 03:00 GMT Dont blind scan. VS gets all channel inf from the sat. I've been getting killer scans of 91-110-119. I delite sat which really just delites channels in channel scan menu. Then I delite all transponders except the first one that produces Q sig. 12224 or 12239 then save and exit to antenna settup checking all three consecutive only use 11250 freq. Exit save out to auto scan Checkbox all 3. No dups and guide info on all.
