Cw800 help???
Username: Juchito97
Post Number: 36
my cw800 is working 100% but this is my problem, i got the same channel 3 or 4 times, like i got channel 300 3 times before go to 301,help.
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 603
Luis delete sat and rescan
Username: Juchito97
Post Number: 37
how i delete sat?
Username: Lklives
Post Number: 14246
Every time U do a scan U are adding the channel again..
Plymouth is right, U can delete em (channels, sats etc) all individually....or just start from scratch with a factory default/reset in receiver menu, which will remove all the channels and then just once rescan em...
Always SAVE and WRITE down your antenna settings, and reinput them after factory default/reset...
Username: Juchito97
Post Number: 38
when you do a factory default you have to load the bin file again or the file stay there?
Username: Metallica
Post Number: 240
after you press factory default the file still in there don't worry..now just do a SAT scan you are done.
Username: Whynot
Post Number: 14
bin file will not delete or go away until you overwrite it with another bi file
Username: Metallica
Post Number: 241
one more thing..go back to your SAT setting and reconfigure it again.
Username: Juchito97
Post Number: 39
thanks alot guys.
