CONAXSAT
Username: Ong_tu
Post Number: 348
This is an upgrade file for DivX side of the Trio
THIS IS FOR TRIO UNITS ONLY
THIS NEEDS BE LOADED THROUGH THE DIVX PORT ONLY!
DO NOT POWER THE UNIT OFF DURING THE UPGRADING, ERASING, OR WRITING PROCESS! YOU WILL KILL THE DIVX IF YOU DO! YOU HAVE BEEN WARNED!
Update Info:
All Trio units are imported with this new flash upgrade
This file can be used as a standard upgrade BUT can also be used if you are having DivX issues
