i just felt like doing this today so i ran my power wire rca's and remote wire back. i dont have back speakers so its a 4 channel rca so i put 2 in the F speaker inouts and 2 on the sub inputs is tht ok.
and scott i didnt hook the remote wire up in the back bcuz my hands were getting to cold to do this tedious work i jus wrapped it around the rcas to make it quick and easy to get to.
i didnt install the fuse yet bcuz the damn kicker fuse has an allen screw in it tht i cant unscrew i think its stripped bcuz 1 side opens but the other doesnt and i didnt strip it. the distro blocks are like tht to some open some dont and they are all the same size well at least supposed to be.
Yea I cudnt get the rcas down the other side of the car. I've had them on the same side plenty of times with no problems. Why aren't u supposed 2 anyways I forget signal noise.
Don't worry Dwight I have 2 sets of RCA cables run right next to 2 runs of 1/0awg and I have no noise issues because they're good RCA cables. If they're really crappy with no shielding or anything they'll pick up interference.
