Switching Problem
Username: R_d_g
St. Louis, Missouri
Post Number: 13
I have a KOOlsat 4000 and 6000. I have 2 dishes, one with legacy twin for 110/119,and the other with legacy dual for 91. I have 1 coax from each in different rooms. I tried SW21 switching but when i change channels on DN that are on different sats it changes SW21 instead of internal switch in lnb. Are my settings wrong or do i need a different type of switch? Is it even possible to do what i am trying? All sats have good signal and work good when connected seperately. I also renumberd Bev so that channels would not interfere with each other.
Username: Kirankumar
Kenya
Post Number: 1942
i think a dp34 switch will be good for you'
it has 3 inputs and 4 outputs
Username: Rtap
FL
Post Number: 1931
african come see me at crazy
Username: R_d_g
St. Louis, Missouri
Post Number: 15
I have 1 coax from each dish going to each receiver. One carries 110/119 and the other 91. Would a 22khz work in this situation?
