I was watching TV with the setup I already have...And all of a sudden it was gone...I'm using bin 080301x...Signal strenght is 60% (that's the most I always get anyways) but I get no quality % at all...I tried turning it off with the back switch but that didn't work....Is this enough info?...
Victor the answer is "no" we need to know whitch sat is a problem and sat setup. go to menu -installation -antenna setup and what you see there like: Satellite--- lnb power--- lnb type--- lnb high--- lnb low--- tp freq--- diseq 1.0--- motor--- legacy SW---
Victor, if you have only sat 119 connected and a dishpro LNB you just have to change TP freq to 12239....if you have other LNB set type to standard....
Ok change lnb type for standart and tp freq for 12239 quit and save and autoscan If dont Work goto viewsatusa/support and download Loader 1 - Firmware Updater (Plat and Xtreme) and last bin Note switch off 5 secs before and between each download Good luck Reply
no ,no too much , just changes of ch and back to the same ch,, is all, use bin 07122X for the Xtreme, I am using this bin ,is better than nothing. wide open
