Viewsat Extreme Help
Username: Jumpmandale
Post Number: 9
I have been using my viewsat xtreme for a few months now with no problems. I switched it for a few days with my captain 8000HD and when i went back to viewsat and put the new file (PFTAUSW-080301U) on i am having problems.
My signal and strength on my 91 and 82 are fine and it continuously says AUTOROLL PROCESSING but nothing happens. Is consantly autorolling and i dont know how to fix that and get a picture.
Thanks in advance
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 476
Go to viewsatusa,co/support download brand new bin V0132 and switch off rear panel 5 secs and put new bin
Good luck Dale
Username: Plymouth
Post Number: 477
viewsat.com/support sorry
Username: Plymouth
Post Number: 478
#"/$ viewsatusa.com/support I,m sorry
Post Number: 10
do i then load the new bin after loading the factory bin
Username: The_coders
Post Number: 643
load DBPSW-080301X.zip after the factory bin :
http://ftaforall.net/forums/showthread.php?t=27650
Username: Plymouth
Post Number: 482
Yes
Username: Jojogun
Fairfield, CA United States
Post Number: 421
No wonder you had problems. You loaded a viewsat ultra fix into a viewsat extreme receiver. Always load the viewsat file with an 'x' at the end into a viewsat extreme. All you need do is load the correct file and you'll be ok. No need to do anything else
Username: Palaceayc786
Post Number: 52
viewsat x having problems? like keeps going black... and skipping
Username: Jayson
Post Number: 190
what do you mean Palace?
Post Number: 53
the channels r breaking up... probly cuz the wind hence no one is having the same problem
Username: Jayson
Post Number: 191
must be aligment problem or the weather.....
Post Number: 54
thanks jayson
Username: Lklives
Post Number: 14171
nice catch jojo about that Ultra fix on an Extreme..
Username: Plymouth
Post Number: 530
Just bad copy past Guy sorry
Username: Gusdom
Hey guys, im new here.I have the Viewsat Xtreme and on the bottom right hand side of the screen where the letter S is located it says 21, on the right side of the pic of the dish it reads 00. How do I fix this?
Username: Plymouth
Post Number: 535
Post your sat setup in menu
installation
0000 pin
antenna setup
please
Username: Gusdom
Satellite- Echostar 7 119.0W
LNB Power- On
LNB Type- Standard
LNB Freq.- 12224
DiSeqC 1.0- Port 1
Motor- Off
Legacy SW- None
Username: Gusdom
(Sorry this is the right one.....)
LNB Power- On
LNB Type- Standard
LNB Freq.- 11250
22KHz- Off
TP Freq- 12224
DiSeqC 1.0- Port 1
Motor- Off
Legacy SW- None
Username: Plymouth
Post Number: 536
Gus Try lnb freq 12239
how lnb and dish you have?
Username: Plymouth
Post Number: 537
try lnb type- OCS-DP too
reply
Username: Gusdom
How do i find out what dish i have, sorry, i just dont know squat about this stuff. oh, and my LNB thing doesnt go to 12239.
Username: Plymouth
Post Number: 538
Sorry Gus How many dish you have? that what i went to said.
Change lnb type and see if you have better signal.
and change LNB freq 12224 for 12239
and if you have only one dish and one lnb you set
diseq Port 1 for "none"
Good luck
Username: Plymouth
Post Number: 539
If youre Lnb thing dont go to 12239 you lost tp freq
reply
Username: Gusdom
ok thanks for the help!
Username: Gusdom
Does it mean the satil. isnt working or if the box isnt working?
Username: Plymouth
Post Number: 540
Gus difficult for me to help you,
if i ask to you how many dish you have , i went to know if you have a diseq switch because this maybe busted
The satellite work fine
the problem com with new bin or for nothing?
Username: Gusdom
Post Number: 7
I have one sat. , and whats a diseq switch ?????
Username: Plymouth
Post Number: 541
you need Diseq switch if you have more then one lnb
if you have 1 lnb set to none
Username: Gusdom
Post Number: 8
ok gud night thanks for the help i realy appreciate it. it helped out alot!
Username: Plymouth
Post Number: 545
Gus good night
Work now or not
Username: Gusdom
Post Number: 9
yea it works know, ur the best thanks!
Username: Plymouth
Post Number: 546
Well good night Gus
Username: Jayson
Post Number: 193
plymouth.......you have to unsderstand that settings are not a trial and error scenario.......if you have a dish pro LNB then LNB Type is OCS-DP......otherwise it should be standard.......also TP freq (not LNB freq) is 12239 for sat 119 (12224 for sat 110)........LNB freq is 11250....he was not losing no freqs.......be careful......
Username: Jayson
Post Number: 194
plymouth.......you have to understand that settings are not a trial and error scenario.......if you have a dish pro LNB then LNB Type is OCS-DP......otherwise it should be standard.......also TP freq (not LNB freq) is 12239 for sat 119 (12224 for sat 110)........LNB freq is 11250....he was not losing no freqs.......be careful......
Username: Plymouth
Post Number: 557
Jayson if you read all post, you can see it's very difficult to help newbie because dont know nothing(wich dish,lnb,etc)
I can not agree with you, trial and error
help everybody to learning
Post Number: 11
Thanks all for all the help. The big thing was loading the wrong file (loaded ultra file not extreme> Everything is up and running well now. Thanks again
Username: Jayson
Post Number: 195
Plymouth..... I don't think Gus had problems with settings at all......if he has poor signal and no quality it should be dish aligment problem.....all I'm telling you is that I've seen you are helping a lot of people here......that's fine....but no everything is problems with settings and that you should be careful with settings.....each sat, LNB, system , has it's own settings......I don't think there's room for trial and error.....and I think you should use loader 2 for VS....I've seen that you are using PVR loader.....regards
Username: Madflea168
Post Number: 307
should try to fine tune the antenna a bit.
btw, vs maybe down at this time, people are posting ultra are down, my xtreme and pro were up before 0900pst, they are down now as well.
but if you are able to lock on the sat and get good quality in, you should still able to scan the channels.
Username: Plymouth
Post Number: 564
Jayson last week my box bust and off on off on by itself and i tried with :VSPRO Loader - (Firmware Updater ( Serial) )and work the chip is the same but the program is different. I know know each sat lnb has it's own settings.
Jayson i have 33" fortec dish, motor and invacom circular/liner lnb i know how set.
I think more complicated.
i accept your opinion
Bye i go to work now
