Loading the factory file???
Username: Nub2fta
N/a, N/a Canada
Post Number: 139
To All, I have a question to ask... If I load the factory file - VS2000 Platinum & Lite Factory Bin File - V0278, will that wipe all clean? Now, if I were to create a back-up on another Platinum, but load it into the first Platinum, essentially I should have 2 identical stb's right? Anyone?
nub.
Username: Saqeeb9000
Mughe dard rehta hai, ..., Mujhe bhook ...
Post Number: 2630
UR question is confusing?
when u load the factory file.. it will delete everthing...
explain ur 2nd question again?
Username: Nub2fta
N/a, N/a Canada
Post Number: 140
sorry... If I have another Platinum in another city, the lnb is set-up for optimal receiving...
if I create a backup file with Platinum# 2... After loading that backup file into Platinum #1(in the other city), will I have successfully created a duplicate stb? with the same channel listing?
nub.
Username: Lklives
Post Number: 14184
receiver is not a PC...just how do u create a "backup file" on a receiver?
there is no purpose to your question...only thing U can do is program each receiver seperately...or have them physically together and transfer data from master to slave using the serial cable
Username: Nub2fta
N/a, N/a Canada
Post Number: 141
ok... picture this, if you have loader2 you have the option to go = stb -> pc, a way to backup info stored on the stb as explained by FTA TESTER... months ago.
Now, say that you and I both have a VS-EXTREME, I use a sat-finder to get (100% signal & 100% quality), and I can pull in say, 1000 channels... If I create a stb -> pc file(backup) that contains the info I saved needed to get those 1000 channels. Now, If you also use a sat-finder to get 100% signal & 100% quality. Would you get the same 1000 channels I get?
nub.
Username: Your_mama
Post Number: 39
Bullshit, just load new factory bin file than load vs file. You will not lose anything, all your channels will still be there.
Post Number: 2640
that's the first time i heard about backup
by the way what happend to ftatester?
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 556
Sada i think you may upload data with loader from Viewsat but i dont try.
On prog we see upload from and download
for my VS ultra i used :
PVR Loader v11 - Firmware Updater ( Serial)
