Galaxy 25
Username: Eliaselias
Post Number: 38
hi i have a true fta there is one TP that is not having quality which is 11789 V that have ALMAGHRIBIA can someone check out please and tell me why i do not have quality anymore knowing all the others are working great less this TP.
I appreciate it really
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 489
Mar-vel nothing for me on this freq
Username: Zahirk
marvel make sure your symbol rate or whatever is it in your receiver is 28125 not 20000 and vertical polarity Enjoy wald khalti
Username: Plymouth
Post Number: 508
Zahir dont work on 11789 28125 v 3/4 nothing when i scan it
Username: Plymouth
Post Number: 511
Do you have it Zahir
Username: Azkab
Post Number: 9
tbarkallah 3la lkhoute...chi 7ed f mississauga?
Username: Bazzoon
Post Number: 11
mar-vel one of two possible reasons:
1- Try different types of your lnb.
a- standard 10750
b- standard 10600
c- universal 9750/10600
d- universal 9750/10750
2- fine tune your dish direction.
I have a universal (type c above) and if I set it wrongly to d, I miss some of and not all the TPs.
Username: One_eye_jack
Post Number: 477
C/P
Arabic Channels
FREE TO AIR CHANNELS
No monthly subscription fees!
Galaxy 25 @ 97.o*W
Arabic Channel name Satellite Name Frequency
2M TV www Galaxy 25 11991-V 22000
Abu Dhabi Sports www Galaxy 25 12145-V 22000
Aghapy TV www (Choose a motorized System) Galaxy 26 11870-V 4167
Al Alam News www Galaxy 25 11836-V 20765
Al Anwar www Galaxy 25 11716-V 22000
Al Fayhaa www Galaxy 25 11966-H 22000
Al-Forat (12053) www Galaxy 25 12053-V 22000
Al-Forat www Galaxy 25 11991-V 22000
Al-Iraqiya www Galaxy 25 12145-V 22000
Alkarma TV www Galaxy 25 11789-V 28125
Almaghribya TV Galaxy 25 11789-V 28125
Canal Algerie www Galaxy 25 11789-V 28125
Jordan TV www Galaxy 25 12145-V 22000
Kuwait TV www Galaxy 25 11991-V 22000
Libyan Jamahiriya Broadcasting www Galaxy 25 12145-V 22000
Middle Eastern Broadcasting Net www Galaxy 25 11933-H 20000
Orange TV www Galaxy 25 11789-V 28125
Qatar TV www Galaxy 25 12145-V 22000
Saudi Arabian TV 1 www Galaxy 25 12145-V 22000
Sharjah TV www Galaxy 25 12145-V 22000
Sudanese Space Channel www Galaxy 25 12145-V 22000
Sultanate of Oman TV www Galaxy 25 12145-V 22000
Tunis 7 www Galaxy 25 11836-V 20765
Yemen TV Galaxy 25 12145-V 22000
Plus more than 22 Arabic Radio stations FREE
Al Maghribya Radio
Radio Quran (Iran)
Radio Tunis International
Radio Maaref
Tunisia National Radio
Radio 2M
Voice of Palestine
Emarat FM
Radio Sout Al-Sha'ab (Voice of the People)
El-Bernameg Al-Aam (Main General Program)
Program One
Radio Quran (Saudi Arabia)
Sudan Radio
Nour Radio
Qatar Radio
Radio Oman
Sana'a Radio
Aden Radio
Voice of Youth
Sharjah FM
Republic of Iraq Radio
Radio Omdurman Holy Koran
Q: How do I get the Arabic channels?
A: Use one of the dish systems below. For the most part any of the satellite dish systems below works to pick up the free Arabic TV stations. In all the different systems, the satellite dish and the LNB are the same. The difference in the system is the receiver.
Q: What's the difference between the receivers?
A: The difference between the receivers is the features and functions of each receiver and the quality of the material used to manufacture each satellite receiver. Our basic system is $149.00. This has all the standard features and will work fine if you are just trying to pick up picture and sound. However, if you like to have functions like blind search / Power Scan / Smart Search / Smart Scan, you may want to spend about $20 or $30 more and upgrade your satellite receiver. Not only will you get a receiver with a better feature, but you'll also get a better quality FTA receiver.
Q: Can I watch Aghapy and the Arabic channels above with 1 dish?
A: Yes. You actually have 2 options if you'd like to do that.
1. Take a look at a motorized systems. These are great systems to use if you want to obtain signal from multiple satellites. Since Aghapy broadcasts from the Galaxy 26 satellite and the rest of the Arabic channels broadcast from the Galaxy 25 satellite, you would need to turn your dish from one satellite to another. Don't worry, you do not have to turn your motor and adjust it every time you want to switch between them. Once installed and programmed properly, the motor will automatically turn as soon as you change channels. The advantage of a motorized dish is that you can pick up signal from more than just the two satellites. You can turn your dish and pick up multiple satellite for literally thousands of free channels.
2. Your other option is to use a 90cm dish along with a multiple LNB bracket, get a second LNBF, then get a 4X1 DiSEqC switch. You will then attach the bracket and LNB to the dish and adjust the bracket to lock in the satellite signal. Considering you have probably spent close to the same time and adjusted the LNBF bracket to lock in your second satellite signal, and you have spent close to the same amount of money on parts, recommendation would be to go with option 1. Get a Motor, and you will bring thousands of channels to your home for free.
Q: What is Blind Search?
A: All the satellite channels are being broadcasted via transponders. Each transponder carries a certain amount of TV and Radio Channels. In order for a normal receiver to be able to scan the channels from a satellite, it must have the transponder programmed into the receiver. Each transponder has 4 specifications.
1. Frequency
2. Symbol Rate
3. Polarity
4. Forward Error Correction (FEC)
In most receivers the FEC is automatically set by the receiver, so you don't have to worry about inputting that in the receiver. You do however need to input the other 3 specifications, then scan in the transponder for the channels.
In case of a blind search / blind scan receiver, the receiver will search the satellite and automatically find the 4 specifications of the transponder. Therefore, you will always have the latest channels that are being broadcasted off of the satellite. Once new transponders are available, all you do is just scan your satellite receiver. The receiver will re-program itself with all the up to date transponder frequency, symbol rate, polarity, and FEC.
Username: Zahirk
Plymouth at what frequence u have 2M? .. if it's 11991 V you should catch Almaghribya at 11789 V otherwise your dish has to be moved little bit.
Username: Plymouth
Post Number: 542
Zahir itry thi setu but dont work
Username: Plymouth
Post Number: 543
Zahir i try this setup but dont work
Sorry
Username: Plymouth
Post Number: 544
I have motor and may adjust with remote but dont work
Username: Zahirk
plymouth do you at least catch any channel at galaxy25
Username: Plymouth
Post Number: 549
sorry Zahir i dont understand this question
Username: Plymouth
Post Number: 550
You went to know if i'm out of zone
possible
Username: Zahirk
Plymouth when you scan Galaxy25 can you get any channel?
Username: Plymouth
Post Number: 555
Yes but i have problem on few freq, my dish(33") well adjust but i think the best for is more bigger like 48" the next i went to buy.
Another think is my universal linear circular lnb is maybe defficient on different freq, idont know
