Bronze Member Username: KiranapPost Number: 12 Registered: Jun-06 | I just loaded NEW GUI (VSPRO-080301A-II). Before loading, I did do Factory Default. Most of the Internationals (All in My fav List) are now showing "Channel Moved". I was watching one just before I loaded NEW even that is moved. My Setup - VSPRO-080301A-II Echostar 9 (121.0) TP freq. - 11742 Any Suggestions? I have tried reverting back to OLD GUI. But now, I get same even with OLD. One more, Everytime I try to setup Antenna Settings ... for Echostar 9 (121.0). TP Freq stays at 11742. I change it to 12132, I get Quality but it changes to 11742 on exit & I loose Q. What am I doing wrong? |
Gold Member Username: KirankumarKenya Post Number: 1927 Registered: Oct-07 | can you post your full settings for all the satellites like lnb type freq,switch everything you see in antenna settings |
Bronze Member Username: KiranapPost Number: 13 Registered: Jun-06 | VSPRO-080301A-II Echostar 9 (121.0) LNB Freq - 9750/10600 DiSEqC 1.0 - Port 2 DiSEqC 1.1 - None Legacy SW - None Motor Type - Disable TP freq. - 11742 Echostar 8,10 (110.0) LNB Freq - 11250 MHz 22Khz Tone - Off DiSEqC 1.0 - Port 3 DiSEqC 1.1 - None Legacy SW - None Motor Type - Disable TP freq. - 12224 Echostar 7 (119.0) LNB Freq - 11250 MHz 22Khz Tone - Off DiSEqC 1.0 - Port 1 DiSEqC 1.1 - None Legacy SW - None Motor Type - Disable TP freq. - 12224 |
Gold Member Username: KirankumarKenya Post Number: 1929 Registered: Oct-07 | for echostar 9 > change lnb freq to 11250, and then transponder freq to 11457 post results |
Gold Member Username: KirankumarKenya Post Number: 1930 Registered: Oct-07 | or try different tran freq once you set lnb to 11250 |
Bronze Member Username: Lookekhoshshans_1356Tehran, Tehran Iran Post Number: 96 Registered: Apr-07 | https://www.ecoustics.com/electronics/forum/home-video/456623.html |
Silver Member Username: Madflea168Post Number: 302 Registered: Jan-08 | the channels may moved from 121 to 118, you will need a dual 118/119 lnb or dn's repoint kit to capture the 118. also, put 119 on port 1, 110 on port 2, 121 or future 118 on port 3. for my vs, I had 10750 to work on 121 before and 118 now, 10600 did not work on me. |
