119/110 problem
Username: Cdeepak
Post Number: 15
If I try to get both 119 and 110 on same dish, I am loosing quality on either 119 or 110.
any solution?
I am thinking to use seperate dish.
Username: Rtap
FL
Post Number: 1927
if you are using a diseq switch replace it.switches are known for giving problems.also check all connections, also check your settings in antenna setup.
Username: Kirankumar
Kenya
Post Number: 1811
before changing your switch,post your settings so we can take a look at it
Username: Satchat
Post Number: 10
I have a 18inch Dish and I am trying to get both 110 & 119 using two LNBs ... as soon as I attached another LNB ... my signal level went down on 110 !!! ... Any idea why ?! ... Do I need a big dish ?!
Thanks
Username: Saqeeb9000
Mughe dard rehta hai, ..., Mujhe bhook ...
Post Number: 2581
ok for 119 you have to change freq to 12ooo somethign it will give you more signals..
Username: Lklives
Post Number: 14126
U just need to align the dish with 2 LNB's correctly, have a working disque switch, good cables and connections...
then input the corresponding antenna settings, scans the satellites, set the date and time, reboot the receiver, upload the latest fix, let the keys roll in..and watch TV..
Username: Madflea168
Post Number: 296
possibly the skew.
check dishpointer.com for more details.
then do your settings.
