Username: Nbpanjwa Post Number: 1 Registered: Feb-08
Monday, February 25, 2008 - 12:08 GMT Can any one help how to get STAR PLUS on CS5000. I tried PID Scan with 12443H TP and V5666, A5667, P5666, NO LUCK OR to add in Channel Master Thanks
Username: Tejneil Post Number: 21 Registered: Mar-06
Monday, February 25, 2008 - 15:43 GMT Same here, no luck with CS5000, followed the same instructions several times with no success. Nalin, Please help!!!
Username: Nydas Post Number: 8496 Registered: Jun-06
Monday, February 25, 2008 - 15:47 GMT I have friends with a CS 4000 or 5000. We could not do anything till the new BINs got released. I can't get in touch with them till this evening. I will post success or failure as soon as I can.
Username: Tejneil Post Number: 22 Registered: Mar-06
Monday, February 25, 2008 - 15:53 GMT Thanks a bunch, Nalin
Username: Nbpanjwa Post Number: 4 Registered: Feb-08
Tuesday, February 26, 2008 - 22:53 GMT Can someone please help me srtup Star Plus on C00lsat 5000????
Username: Nycman77 Post Number: 13 Registered: Feb-08
Tuesday, February 26, 2008 - 23:18 GMT can anyone tell me y chann3l 588 and 605 dn coolst5k isnt workin there my tooo fav intl ones
Username: Kirankumar Kenya
Post Number: 1764 Registered: Oct-07
Tuesday, February 26, 2008 - 23:24 GMT This Will Work MENU---> Channel List---> Channel List Manager----> Edit Channel---> and then press yellow botton ( Add Channel) and then Change channel name Frequency------ 12443 Video PID------ 5666 Audio PID------ 5667 PCR PID-------- 5666 and then press yes now you r good to go for Star Plus :-) i got mine on channel 7222 but could be any channel enjoy
Username: Nycman77 Post Number: 14 Registered: Feb-08
Tuesday, February 26, 2008 - 23:25 GMT hey african u have an answer for me perhaps on my above question?
Post Number: 1765 Registered: Oct-07
Tuesday, February 26, 2008 - 23:29 GMT I have a feeling 605 might be assigned to starplus very soon,as far as 588 i don't know,but i suggest you do blind scan.i am not at home right now,but i can check for you in the morning
Username: Nycman77 Post Number: 15 Registered: Feb-08
Tuesday, February 26, 2008 - 23:33 GMT ok i would appreciate it african thank you
Username: Jppatelahd Post Number: 73 Registered: Sep-07
Wednesday, February 27, 2008 - 00:02 GMT african do u know it is possible on captive works 600 premium? i am asking this questions too many times but nobody comes to help?
Username: Jppatelahd Post Number: 74 Registered: Sep-07
Post Number: 1767 Registered: Oct-07
Wednesday, February 27, 2008 - 02:45 GMT yes on all receivers with 61.5
Username: Leo_here Post Number: 61 Registered: May-06
Wednesday, February 27, 2008 - 07:21 GMT I dont think anyone is getting this channel on CS5K It worked fine on my VS and PS On my CS,I tried everything but all I am getting is a blank channel with no audio or video ANybody knows how to make it work on CS5K ??
Post Number: 1770 Registered: Oct-07
Wednesday, February 27, 2008 - 07:38 GMT Leo i got it on my cs5000
Username: Leo_here Post Number: 62 Registered: May-06
Wednesday, February 27, 2008 - 16:31 GMT What did you do African? I am getting 2 605 channels..first one is greek and second one is coming up as blank !
Post Number: 1777 Registered: Oct-07
Wednesday, February 27, 2008 - 16:33 GMT dont try to get it on 605 like i got it on 1772,it shows martha stewart but star comes on.follow what i have posted and let me know
Username: Krishn Post Number: 87 Registered: Sep-06
Wednesday, February 27, 2008 - 16:57 GMT African: I was trying to help a friend who has CS5000, however Chanel List manager could not be found at all in the Menu. His menu is as follows Menu---> Channels---> Set Favorite | Edit Channels |Move Channels | Lock Channels | Skip Channels | Delete Channels How did you get the choices you posted - "MENU---> Channel List---> Channel List Manager----> Edit Channel---> and then press yellow button ( Add Channel) and then ...." Is it because you have loaded some channel manager that extends the menu? Also tried PID scan for another channel, it first deleted other satellites then deleted all channels. Is it a problem with CS5000?
Post Number: 1780 Registered: Oct-07
Wednesday, February 27, 2008 - 18:01 GMT menu>channels>edit channels. then press yellow button
Username: Krishn Post Number: 88 Registered: Sep-06
Wednesday, February 27, 2008 - 18:02 GMT Anyone has info on Channel List---> Channel List Manager on CS5000, please see the post above and provide your input
Username: Krishn Post Number: 89 Registered: Sep-06
Wednesday, February 27, 2008 - 18:03 GMT Ok thanks sorry - concurrent posting
Username: Krishn Post Number: 90 Registered: Sep-06
Wednesday, February 27, 2008 - 18:15 GMT African - menu>channels>edit channels. then press yellow button This sorts the channels as per the transponder, looked at system info it says Boot version: 2.1 and ch version: 007, may be need a different channel version can you check yours and post
Post Number: 1782 Registered: Oct-07
Wednesday, February 27, 2008 - 18:24 GMT then scroll to 12443 and press ok
Username: Nbpanjwa Post Number: 5 Registered: Feb-08
Wednesday, February 27, 2008 - 18:35 GMT African, Subash is right, I too don't see Channel List Manager. When I do menu>channels>edit channels then press yellow button, I get option to add TP and when I add 12443 then H, I get a message: "TP already exist". I think we may not be using same factory bin as you. If so please send us a link to the factory bin that you are using. We will flash that first and then new bin 168, hopefully then we may see Channel list Manager to add NEW Channel.
Post Number: 1784 Registered: Oct-07
Wednesday, February 27, 2008 - 18:47 GMT got factory bin from ftabins
Username: Nbpanjwa Post Number: 6 Registered: Feb-08
Wednesday, February 27, 2008 - 18:57 GMT African, I got it from the same place too then how come I don't get the same options to add channel as you do???? I have posted the same quiestion on several other sites. No Luck yet... Something is missing somewhere and I'm sure someone out there knows how to fix it... Hope help will be coming soon...
Username: Krishn Post Number: 91 Registered: Sep-06
Thursday, February 28, 2008 - 00:06 GMT nb - the only way you can add is from Menu---> Installation ---> PID scan However be careful, first save the Channels from the loader, since you may loose all channels if you do PID scan. I was helping a friend and noticed CS is not stable. nb what is your boot version and ch version from system info? African could you please post the Boot Version and Ch version from system info?
Username: Nbpanjwa Post Number: 7 Registered: Feb-08
Thursday, February 28, 2008 - 03:55 GMT PID scan did not work for me, I lost all existing channels on that TP and got few others but not Star Plus. Subash, can you explain how you were able to get Star Plus by doing PID scan. Boot Version: 2.10 (09:14) and CH Version: E007 African, Subash what info you got???
Username: Krishn Post Number: 92 Registered: Sep-06
Thursday, February 28, 2008 - 14:55 GMT nb system info mentioned by my friend is: Boot Version: 2.10 (09:14) CH Version: E007 same as yours make sure you enter all fields in PID: Frequency------ 12443 Video PID------ 5666 Audio PID------ 5667 PCR PID-------- 5666 however as african has said channel name may not come up
Username: Nbpanjwa Post Number: 8 Registered: Feb-08
Thursday, February 28, 2008 - 22:26 GMT Subash, as I said earlier that did not work for me. Wonder, why no one else is helping for C00lsat 5000??? I guess, people might have trashed it by now...
Username: Nydas Post Number: 8633 Registered: Jun-06
Thursday, February 28, 2008 - 22:48 GMT Menu---> Installation ---> PID scan Then enter all the values. It worked to get Star Plus on a friend's CS4000 using the latest BIN.
Username: Nbpanjwa Post Number: 9 Registered: Feb-08
Friday, February 29, 2008 - 19:37 GMT Nalin, that did not work for me on CS5000. Anyone other sugesstion???
Username: Jay228 Windsor,
Ontario
Post Number: 22 Registered: Oct-07
Saturday, March 01, 2008 - 00:14 GMT There is no data for Star plus in EPG.
Username: Nbpanjwa Post Number: 10 Registered: Feb-08
Saturday, March 01, 2008 - 19:34 GMT Finally.... I got it. I did -->Factory Reset -->Bilnd scan TP 12443 Got 6 channels but on TP 12445 -->Channel edit on Channel 7772 and entered 5666, 5667 & 5666 respectively where it belongs. -->OK Bingo! STAR PLUS appeared!!!!! Don't give up folks......
