Star plus on viewsat ultra help!!!!
Username: Saaju
Post Number: 8
i followed all the instruction and when i go the USER CHANNEL its blank!! how do i get star plus!!!can anyone help :p
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 474
saaju blank or dont find channel
Username: Saaju
Post Number: 9
nvm Plymount i got it :-) thaks for trying to help me!~~
Username: Det
Post Number: 55
which echo or whch location is 118.7 or 118 is on a pansat 2700a for dish?
Username: Kirankumar
Kenya
Post Number: 1895
m n m,
do you have a 30" or larger dish
that is the first thing you will need
Username: Saaju
Post Number: 10
http://www.dishpointer.com/ go here it will help u out
Username: Det
Post Number: 58
it is bigger than 30.
Kenya
Post Number: 1896
if you have 110 and 119 then you have to change the lnb on 119 so you will get 119 and 118.7
i am not too sure about the lnb type but it is around $25
there were a lot of threads on this here but i can't find it
Nalin knows the exact type of lnb
Username: Det
Post Number: 59
i hav the lnb but i dont know what satellite its pointing at i dont hav anik f3 or amc 16,how to i get bengali channels
Username: Dishall
Post Number: 50
i have 18" dish and watching starplus on cw but not on vs pro any help
Kenya
Post Number: 1897
What satellite are you getting right now ?
m_n_m
Username: Det
Post Number: 59
Posted on Saturday, March 01, 2008 - 01:49 pm:
Username: Det
Post Number: 60
i only hav anik f1 thats it i hav echo 7 and echo 8.1
Kenya
Post Number: 1898
so you have 119 on echo7 and 110 on echo8
what kind of lnb do you have?
if you have 2 single lnbs,then you change out the one for echo7 which is on the left if you are standing behind the dish
Username: Det
Post Number: 61
i hav 2 lnbs the one for 118.7
Kenya
Post Number: 1899
go to
www.dishpointer.com
and adjust your dish as per instructions there
Kenya
Post Number: 1900
go here for lnb
http://www.partsforhdtv.com/lnb-circular-dss-10750-11250-c-81.html?gclid=CI_0z5j S7JECFQQClwodwkJoww
