HELP, I uploaded new bin into Viewsat Ultra, now I have no quality or signal
Username: Ubba
Post Number: 100
I did what everyone said and had the viewsat unfrozen then put in the new bin, but got no signals in any channel. So, did a factory reset and am now doing blind scan and have no channels being dowloaded as quality is 0. What can I do, please help? Thank you
Username: Kirankumar
Kenya
Post Number: 1840
Lisa,
post your settings so we can help
Username: Metallica
Post Number: 211
did you reconnect your cables??
try to turn it off from the back than turn it back on...try that
Username: Ubba
Post Number: 101
My settings, I don't know if you mean the echo star. I download Echo star 3 and echo star 8.10. I tried everything. No channel is being downloaded. Have signal but no quality. Your help is so appreciated.
Username: Your_mama
Post Number: 37
You need to load the newest factory bin than the new vs bin
Username: Ubba
Post Number: 102
where can I find the new factory bin?
Kenya
Post Number: 1846
Lisa
go to menu>satellite
and post the setings that you see there'
like lnb type,
frequency,switch type etc
Username: Plymouth
Quebec city, Quebec Canada
Post Number: 438
When load new bin the sat setup chang and you need to reconfigurate it, post youre sat setup and we help you Lisa
Username: Lol
Post Number: 404
Lisa did you read the instructions ?
Vs- Ultra only
Before loading power off via rear switch and unhook satellite dish cable to allow receiver to properly boot up for USB Loading. After you have loaded file you may power off and hook up satellite dish cable ..
Do it again
Username: Ubba
Post Number: 103
LNB Type: Standard
LNB Frequency: 11250
as for TP Frequency it's different with each channel
Kenya
Post Number: 1847
i need all the info for each satellite
Username: Ubba
Post Number: 104
Paul, I did all of these, mine is VS Ultra. Nothing worked so I did a factory reset as I was able to change channels, but everything was 0 in quality.
Username: Ubba
Post Number: 106
I only have 2 satellites and have echo star 3 and echo star 8.10. For each TP Frequ. it's a different number. I'm getting this info from someone who has the same info as the VS Ultra I have. Nothing is working. I have tried to add channels twice, but nothing has been added since Q is 00 all the time. Do I have to load a new factory bin and where do I get it?
Username: Plymouth
Post Number: 441
Dont need to make factory reset this is the problem why you lost all setup but sometime the port change and motor setup with new bin
Kenya
Post Number: 1849
if someone gave you the info then sort your problem out yourself
GOOD LUCK
Lisa
Username: Ubba
Post Number: 106
Posted on Friday, February 29, 2008 - 10:08 pm:
Username: Ong_tu
Post Number: 334
Hey sand Nig*er if you can't answer the post get your dumb a*s off the site "retard"
Kenya
Post Number: 1850
F@ck you
you spamming azzhole
Username: Ubba
Post Number: 107
African, I appreciate your help, but don't need this childish behavior right now. If others are trying to help me, I truly appreciate that. So, anyone out there who is genuinely trying to give me advice, please help as I have no channels and don't know what to do?
Username: Plymouth
Post Number: 444
Hi Ong_tu Gramma
Username: Ong_tu
Post Number: 338
Plymouth and the sand nig*er lol! Pathetic little kids lol! Watch your language sh*tmouth may be offended lol!
Username: Luser
Post Number: 83
Most likely your antenna setting changed from a memory crash caused by this latest ecm. Go to antenna setup and scoll through each one even if its correct then change it then back keeping an eye on your quality and confirming the sat your on is the sat that displays when quality is good. Other than that its something like cable inadvertantly removed and replaced on wrong port or something like that.
