Username: Pu_da_munda Post Number: 60 Registered: Feb-07
Monday, March 03, 2008 - 01:52 GMT I hv viewsat ultra and all Indian channels are not showing since yesterday. Can anyone tell me whats the problem?
Username: Plymouth Quebec city,
Quebec
Post Number: 502 Registered: Jan-08
Monday, March 03, 2008 - 02:01 GMT Sidhu Which sat and channel
Username: Pu_da_munda Post Number: 61 Registered: Feb-07
Monday, March 03, 2008 - 02:04 GMT DN and all Indian channels like Zee, SET, MAX , ETC punjabi etc.... Its keep on saying autoroll in process..... and nothing is displayed for these channels.
Quebec
Post Number: 504 Registered: Jan-08
Monday, March 03, 2008 - 02:11 GMT Dish have 61.5 110 118.7 119 121 148 Which one
Username: Pu_da_munda Post Number: 62 Registered: Feb-07
Monday, March 03, 2008 - 02:17 GMT echostar 8.10
Username: Pu_da_munda Post Number: 63 Registered: Feb-07
Monday, March 03, 2008 - 02:18 GMT echostar 6,8 110.0W
Username: Pu_da_munda Post Number: 66 Registered: Feb-07
Monday, March 03, 2008 - 02:34 GMT Plymouth can u help me getting the channels?
Quebec
Post Number: 505 Registered: Jan-08
Monday, March 03, 2008 - 02:35 GMT # channel please i can check if work for me and give freq for scan
Username: Kirankumar Kenya
Post Number: 1911 Registered: Oct-07
Monday, March 03, 2008 - 02:39 GMT Sidhu, post your settings fao all satellires you have so we can help
Username: Pu_da_munda Post Number: 67 Registered: Feb-07
Monday, March 03, 2008 - 02:39 GMT 0617, 0618, 0619,0620, 0622, 0612, 0576, and so on...
Post Number: 1912 Registered: Oct-07
Monday, March 03, 2008 - 02:42 GMT no no no go to menu> Satellite then you will see settings like frequency lnb type switch etc etc post everyting
Username: Pu_da_munda Post Number: 68 Registered: Feb-07
Monday, March 03, 2008 - 02:46 GMT SAT settings for echostar 6,8 110.0W LNB Power : ON LNB TYPe : OCS-DP LNB Freq : 11250 22KHz : Off TP Freq : 12224 DisEqc1.0 : None If you need any other information please let me know
Quebec
Post Number: 506 Registered: Jan-08
Monday, March 03, 2008 - 02:47 GMT It's same for me, i do a blind scan and i reply. Do a blind scan too
Post Number: 1914 Registered: Oct-07
Monday, March 03, 2008 - 02:49 GMT Sidhu, do you have just one satellite? because if you do then you are not going to get Indian on this
Username: Pu_da_munda Post Number: 69 Registered: Feb-07
Monday, March 03, 2008 - 02:52 GMT No, I have Echostar 3 and echostar 7 also
Quebec
Post Number: 507 Registered: Jan-08
Monday, March 03, 2008 - 02:54 GMT African is it possible Indian is on 61.5w and not on 110w
Post Number: 1917 Registered: Oct-07
Monday, March 03, 2008 - 02:55 GMT go to settings again and post the settinga like you did for this one SAT settings for echostar 6,8 110.0W just change the first line for the satellite your problem is with switch settings if you post i will fix it for you
Post Number: 1918 Registered: Oct-07
Monday, March 03, 2008 - 02:59 GMT DisEqc1.0 : None change this on all 3 sats then next line will come up for 119 > 1 OFF OFF for 110 > 2 off off for 61.5> 3 Off off
Username: Pu_da_munda Post Number: 70 Registered: Feb-07
Monday, March 03, 2008 - 02:59 GMT African you need the setting for Echostar 3 and Echostar 7? Just give me 2 mintues please
Post Number: 1919 Registered: Oct-07
Monday, March 03, 2008 - 03:00 GMT change this DisEqc1.0 : None on all 3 sats then next line will come up for 119 > 1 OFF OFF for 110 > 2 off off for 61.5> 3 Off off
Quebec
Post Number: 510 Registered: Jan-08
Monday, March 03, 2008 - 03:06 GMT This channel are on 65.1w I confirm
Username: Pu_da_munda Post Number: 71 Registered: Feb-07
Monday, March 03, 2008 - 03:09 GMT I tried to do AutoDiscEqc for all satellite but it doesnt work.
Post Number: 1922 Registered: Oct-07
Monday, March 03, 2008 - 03:11 GMT if you go to disceqc and click on it then you can change to 1.1 or something like that
Quebec
Post Number: 513 Registered: Jan-08
Monday, March 03, 2008 - 03:12 GMT Sidhu listen African he help you for this I have one lnb and motor my switch setup is different
Username: Pu_da_munda Post Number: 72 Registered: Feb-07
Monday, March 03, 2008 - 03:12 GMT it says Port 1 to Port 4
Post Number: 1923 Registered: Oct-07
Monday, March 03, 2008 - 03:13 GMT ok set 119 on port 1 110 on port and 61.5 on port 3 and it should work
Username: Pu_da_munda Post Number: 73 Registered: Feb-07
Monday, March 03, 2008 - 03:14 GMT I can see all other channels on 61.5 like Boomerang, Movies, PPV but all Indian channels are missing/not showing? I sincerely thanks Plymouth and African for your effords and time.
Username: Pu_da_munda Post Number: 74 Registered: Feb-07
Monday, March 03, 2008 - 03:17 GMT Sorry guys, I changed the setting as mentioned but still cannt see these channels.
Quebec
Post Number: 515 Registered: Jan-08
Monday, March 03, 2008 - 03:17 GMT Do a blind scan on sat where you have lost channel that recovered it
Username: Pu_da_munda Post Number: 75 Registered: Feb-07
Monday, March 03, 2008 - 03:18 GMT I hv all the channels in the list but on selection its keep on doing autoroll processing..
Username: Pu_da_munda Post Number: 76 Registered: Feb-07
Monday, March 03, 2008 - 03:20 GMT Even I hv installed the factory setting file and new bin file...but all in vain
Quebec
Post Number: 516 Registered: Jan-08
Monday, March 03, 2008 - 03:27 GMT OK try to switch off rear panel 5 secs (hard boot) if dont work go to channel scan and delete sat and reinstall it
Username: Pu_da_munda Post Number: 77 Registered: Feb-07
Monday, March 03, 2008 - 03:30 GMT I turned off the rear panel and after reboot it says no channels and i have to do blind scan.. its in progress.. lets see
Quebec
Post Number: 518 Registered: Jan-08
Monday, March 03, 2008 - 03:38 GMT Sidhu between and before each install bin do a hard reboot 5 secs that why you box is in trouble you need to empty intern memory like a computer
Username: Jayson Post Number: 189 Registered: Aug-06
Monday, March 03, 2008 - 15:40 GMT sidhu......you need to make sure that you have the satellites in the right port just as you assigned them in the settings.....also make sure your LNB is Dish pro....if not you have to change the LNB Type setting to standard........
Username: Rzkaps Toronto,
Ontario
Post Number: 5 Registered: Nov-07
Monday, March 03, 2008 - 17:33 GMT Hi Guys, I have Viewsat Ultra and like Sidhu, I am not getting Indian channels and American channels like ABC, which we used to get with FORTEC receiver earlier. I kept playing with the settings and now my Satellite is showing EChostar 3 360W instead of 61.5. How do I change this back to 61.5. I have only one dish. I am getting European and Arabic channels. Do you have to change any settings to get the normal DN channels. The channel list is showing so many channels, but when you click on the channel, it keeps searching for the signal. Please help
Quebec
Post Number: 524 Registered: Jan-08
Monday, March 03, 2008 - 17:50 GMT Rashida go to menu installation 0000 pin code antenna setup go to motor selected Usals enter supposed to see on third lines " echostar 3 61.5w if not arrow up and write "615" and down arrow for "w" and "ok exit save reply please
Quebec
Post Number: 525 Registered: Jan-08
Monday, March 03, 2008 - 17:55 GMT Rashida how many dish you have wich sat you went give a little more information please
Quebec
Post Number: 526 Registered: Jan-08
Monday, March 03, 2008 - 18:18 GMT ""The channel list is showing so many channels, but when you click on the channel, it keeps searching for the signal."" You need to delete sat and rescan this channel are encrypted or from another sat etc. I have same problem when test scanning
